I was on a big old meaty Lake District ride yesterday and there was a bit of squeaking noise when I was doing the sort of power manoeuvres you need to do to get over big rocks on a climb. At the top of the hill the pedals just span and that was it, ride cut short and coasting down what was supposed to be the last of a few descents.
Turns out the ratchet ring has come loose in the hub – it’s a Spank hub, I can’t find one of their ratchets anywhere online for sale, and if I’m honest even if it is replaceable there’s swarf in there that suggests the soft alloy of the hub has been worn away and the hole will now be a bit big for it.
Anyone got any idea how to bodge this back together to save me spending loadsamoney on a new wheel? Initial thoughts are to get the ring out with a bearing puller then tap some knurls into the inside of the hub and araldite the ring back in. Sound reasonable (assuming that the wheel is essentially worthless now anyway)?
