These guys have a 51.8x40x8 45 degree:
here
Could be made to work if the bore is a bit over. I take it it’s going into a carbon bore on the frame, rather than an alu cup? If so then some very careful sanding would get you there.
They also have a 51x40x7. If you put a *very* slightly greasy (as in wiped off) bearing in to the bore with some toughened epoxy at the sides, and assemble the headset before it dries (and rotate the bars a bit to ensure it’s squared) then it’ll sit where it wants to be and should still be fairly easy to remove when you need to. Degrease the frame a lot first, and the epoxy should stay put permanently
Neither of these are good for your frame warranty (but this is PX, so meh), and the first is obviously a bit more drastic… Up to you if you think the material is thick enough.
