Viewing 6 posts - 1 through 6 (of 6 total)
  • Replacement headset bearings…. Crane Creek
  • Premier Icon alpin
    My headset is creaking.
    I understand that Crane Creek sell replacement bearings, but I’m confused.
    Have a Crane Creek Forty headset but what bearings do I need?
    Premier Icon simondbarnes
    It depends on your frame & fork
    Premier Icon nickdavies
    Go on the cane creek headset finder, put your frame and fork details in – itll give you the correct specs. Now order the correct bearings from crc, or source generic ones to the same specs. If its integrated its probably just the lower you need.
    Premier Icon mechanicaldope
    I brought some from Bird I think. Didn’t notice any variety of sizes. Think you have a choice of steel or ceramic. I went with steel for about £20 I think.
    Premier Icon mark90
    I found it more cost effective to replace my CC40 lower with a Hope. The upper is still ok but the lowers just didn’t last long.
    Premier Icon bungalistic
    I also found some Hope ones that fitted and they lasted longer than the Cane Creek ones.
The topic ‘Replacement headset bearings…. Crane Creek’ is closed to new replies.
