Fed up with my Bontrager Drop Line and its continued faliures!
I managed to squeeze the 150mm Bontrager dropper in to my frame, but it does rest againt the bend in the frame on my Trek with its stupid curves!!!
Looking at the Fox Transfer as an option and think it has a pretty similar insert length, but the bottom where the cable goes in looks longer and a bit wider so I dont think the 150mm will fit so might have to go 125mm.
The Reverb is another option. The insert length is the same looking at a chart I found online and because the cable is central and quite narrow this might make it further in the frame.
I’m not sure its wise to have it resting on the bend in the frame but guess it doesnt do any harm?
Anyone with an 18.5 Trek Squeezed the above in?
