used to always have a remote lock out. Useful when you are not very good at reaching down when riding up a steep hill or barrelling down a decent and have forgotten to switch and very useful when you are mid air and remember your forks are locked out 😀
Just built a new bike with a remote lock out and it’s a PITA. One of the newer rockshox push locks so an awkward shape like a reverb lever yet somehow even worse. Has ended up stuck vertical behind my shifter. It’s not an ergonomic lever position but it doesnt have to be, unlike a reverb were you really will be using it on the fly. It might get moved further in board when I start riding it so slightly more convenient than a crown mounted one but not worth the clutter.
A remote dual position button would be more useful on my long travel hard tail.
On the full susser no need to touch the shock.
On another note I prefer being able to adjust my compression damping on a non-remote lock out fork. I did have an old remote lockout/compression adjust knob (lever broke off in my torso during a crash leaving a lever shaped hole when it pulled out still attached to the cable) which you could set the compression damping with as well as lock out. But it took about 20 turns for the full range so was a load of crap really. A crown mounted knob has say 6 clicks and you quickly learn to flick it back to where you had it and maybe adjust the damping a bit depending on the terrain. A much more useful feature than a remote lockout.
