Viewing 40 posts - 1 through 40 (of 104 total)
  • remembering which way to undo pedals? gnfckrackghahh!@#$&(@!
  • big_scot_nanny
    As I’ve mentioned in the past, I have to dot about various places for work, and try to take my hardtail when I can. Got my system pretty much down-pat with my ancient DHB bike bag. (that refuses to die, can’t justify a Evoc one… yet!).
    The one buggery thing that always has me googling, holding my phone upside down etc is taking off the bloody pedals. Sometimes bike is on a stand right way up (at home), sometimes its upside down resting on bars/saddle (in hotels).
    This simple process, esp when upside down and park tools website instructions are for right way up, is simply something that brain cannot cope with. Really, I just stand there with brain matter dribbling out my ears and slack look on my face.
    So – any tips? for the love of god, help me – when the bike is upside down, which way do I undo the pedals, and what system can you advise me to remember!
    ta muchly you beautiful, lovely bunch
    xx
    orangespyderman
    Wrench on/in upwards, move it towards the back of the bike.
    EDIT : you said upside down. Wrench handle towards the saddle, move towards the back of the bike.
    sockpuppet
    When you’re putting them on, you can use the chain to hold the cranks still still tighten the pedals against it.
    Removing it’s the opposite! So if you’re ‘removing’ the pedals by pulling against the tension in the chain you’re doing it wrong! Turn the way that would slacken t(e chain and make the free hub back-pedal if you let the cranks turn.
    scotroutes
    For a bike sitting on its wheels, it’s pedal to the front, wrench to the rear, press down. I usually use my foot.
    Reverse if the bike is upside down. I reckon it’s always better to be pressing the wrench down than pulling it up.
    zippykona
    Left is right
    Right is wrong
    RoterStern
    To undo always turn towards back of bike. Simples.
    tomhoward
    Hold the spanner still, horizontally, and back-pedal (wheel not moving) to tighten. Same but pedal forwards (wheel moving) to loosen.
    big_scot_nanny
    vongassit
    Foot on pedal & pull up on allen key/wrench.
    big_scot_nanny
    Can I just remind folks about the question:
    When the bike is upside down, sitting on handlebars and saddle…
    Nobeerinthefridge
    This.
    Bez
    Left is right, Right is wrong
    Er, no, that’s BBs. Right hand pedal is right hand thread, left half pedal is left hand thread. BB is Bloody Backwards.
    Handedness of the thread doesn’t change when you turn the bike upside down…
    hols2
    As above, RH pedal is RH thread, LH pedal is LH thread. When you turn the bike upside down, the sides of the bike are reversed.
    For a RH thread, point your right thumb along the axis of the bolt or pedal axle in the direction you want it to go (i.e. towards the outside of the bike to remove a pedal) and curl your fingers. You turn the spanner in the direction your fingers are pointing. For a LH thread, you do the same thing with your left hand.
    Exactly! But the left pedal is now on the right 😆
    Crank side is normal thread. That’s all you have to remember innit.
    Gets complicated when you have allen key from the back, and spanner from the front.
    I never do my pedals up really tight, so can feel straight away if I’m going the wrong way. A gentle push will either undo it or tighten it.
    Bez
    Well, they’re not. But if you think they are, simply look at the bike from the front* and hey presto, problem solved 🙂
    * If you find that turning the bike upside down also turns the front into the back then put the spanners down and get an adult to help 😉
    kayak23
    We talking northern or southern hemisphere?
    Bez
    Ah, yes, be sure to check that your cranks don’t have Coriolis threads 🙂
    benpinnick
    Bike upside down, crank arms facing backwards & upwards at 45 degrees, allen key in pedal, level & facing forwards towards the front axle. Push allen key down.
    big_scot_nanny
    Ah, good point Dez B- yes, its Allen key from the back, which you are utterly and totally correct in stating adds another left right up down flip flop variable…
    I’ve got a huge smile on my face reading all the responses, as what is playing out is exactly my internal monologue each time… hilarious 😆
    StuF
    This +1, heel of the foot when your foot is on the pedal
    If the bike is upside down, turn it the right way up and use above method
    Bez
    Why don’t you just get some small, plain, vinyl stickers and a fine permanent marker, and stick them on the back of each crank arm to show two arrows labelled “fit” and “remove”?
    Or just one arrow saying “fit”. You’ll probably work out the rest 😉
    Bez
    I’m assuming nothing 🙂
    simondbarnes
    Hahaha!
    BigJohn
    The way I remember it is thinking back to that Sideways Cycles Thursday night ride when my pedal bearing started to stiffen up and my pedal kept undoing itself and falling off.
    nach
    They come off the same way a wheel would turn if you rolled your bike backwards. They screw on the same way as a wheel spins when the bike’s going forwards.
    I’ve had various other methods, but the above seems to be almost completely idiot/hangover proof.
    hols2
    Well, they’re not.
    Sure, if you take it literally instead of considering what words mean.
    philjunior
    I always remember that you can do pedals up by backpedalling via a pedal spanner. So forwards pedalling to tighten. Easier with the back wheel in, to double check you’re doing it right.
    greyspoke
    If you can get things right when the bike is upright, I find a good way of visualising that when the bike is upside-down on the ground is to stand in front of the handlebars looking at the bike. It is like you just looped out of a wheelie and caught it – the handlebar on your right is the right handlebar, the one on your left is the left handlebar, same for pedals.
    Bez
    Surely “considering what words mean” is literally “literally”? 🙂
    So when you turn your bike upside-down you suddenly have a left hand drivetrain? No. It’s still on the right side of the bike. Just as when you look at an upright bike from the front, the right side of the bike is still where it was, even though from your viewpoint it’s on the left.
    Your right hand is still your right hand when you do a bungee jump, because we take the reference point on nominal left/right sides as being the thing—bicycle, bungee jumper, whatever—they’re attached to, assuming that thing has some inherent orientation (ie you don’t have a left/right side of a football). If you use a viewpoint as the reference point, that’s completely transient and arbitrary and it makes it completely impossible to even talk about anything having a left or right side.
    THIS IS WHY SOME PEOPLE NEED BOTH ARROWS ON THEIR STICKERS
    wombat
    Why not just fit/remove the pedals when the bike is the right way up?
    simondbarnes
    If I ever have to remove pedals with the bike upside down I find it easier to stand upside down too, that way it’s the same as if the bike was on its wheels.
    Bez
    Simon, I assume you’ve got one of those workshop mechanic’s caps that makes it easier to fit cranks while upside down?
    antigee
    As Tomhoward and philjunior said undoing is like pedalling backwards also i have it written on the spanner i use most often with a marker pen L undo Clock R undo Anti i guess if Left Right get complicated when you invert the bike then Chainring side and Crank only side?
    hols2
    Pedantically, yes, but real people use langauge to say what they think, not just talk about dictionaries.
    PJay
    Isn’t it the opposite way to bottom brackets?
    scuttler
    If the bike is upside down then to undo the pedals you push the wrench down and towards the back for both sides.
    Bez
    Of course. You’re taking “what words mean” too literally 😉 …or at least too narrowly.
    Context is everything. Left and right must always have a reference point, they’re entirely meaningless without it.
    We each carry a reference point with us, of course: our vision. But that’s not the only one.
    If a thing “has a left/right side” then the reference point is that thing (which must also have a natural top/bottom and front/back, otherwise it can’t have a left or right: a wine glass has no left/right because it has no front/back, and a reflector in a torch has no left/right because it has no top/bottom).
    Evidently, some people struggle with the idea of objects have inherent/natural sides like this, and appear to resort to the left/right that are derived from their own viewpoint.
    That doesn’t mean a bicycle doesn’t have a consistent left and right, it just means you struggle with a reference point other than your own.
    But again, it seems odd that turning a bike upside down flips the sides for you, but presumably you don’t struggle the same way when you walk to the front of the bike. If you look at a right-hand drive car from the front I’m guessing you wouldn’t say the steering wheel was now on the left of the car, just as you wouldn’t if you found the car upside-down on its… well, presumably now it’d be it’s bottom, so… we… nope, it’s all broken.
    If we always used only our own reference points we’d never be able to discuss anything without… well, all this 😀
    I’m glad I came back to this discussion. It’s brilliant 😆
    there are barnys all over the web about it!
    But look what someone pictured
    Wowza
    So for allen keys – attach your marked spanner to the front of the pedal and follow the arrow direction!
    onehundredthidiot
    With pedal level at 9&3, turn towards the frame. Can’t do it with the rear pedal as the frame is in the way.
The topic ‘remembering which way to undo pedals? gnfckrackghahh!@#$&(@!’ is closed to new replies.
