I have had 2 mechanicals resulting in me walking home in the last 2 years (last one 2 weeks ago). Both were due to chain snapping and both chains had been split and rejoined with a chain tool numerous times (due to change of ratios on fixed gear bike)
I am never going to rejoin a chain again and am now intent on keeping same gearing for life of chain…
Simple solution to that is to use the spare chain when you get a new one to make up a set of extensions. Then put two quick links in the chain next to each other in the shortest ratio you’ll run. Track ends should give enough adjustment for about 4-5t difference so if setup correctly you need extensions about 3/6/9 half links long (i.e. 1.5″, 3″, 4.5″).
OTOH, I’ve never broken a track chain when I have had to join it without a link. The thicker side plates seem much more resilient to bodging, and they’re not being twisted.
