I’ve watched the SRAM videos and have checked what I’m doing but I’m none the wiser – can anyone tell me what I’m doing wrong?
I’ve cut and reinstalled a pair of SRAM axs hydraulic brakes. I reinstalled the hoses using the proper sram red olives and barbs.
Where I’m goofing up is on the refilling of the brakes with dot fluid.
I’ve attached the bleeding syringes (both 1/2 full) to the bleed ports on the lever / calliper. Both ports are definitely open but I can’t seem to inject any fluid into the hoses. I’ve removed the syringes, checked the bleed ports are open and that the “clips” on the syringes are both open … but no joy.
It feels like there’s a blockage in the system but the whole set is new so that’s unlikely.
Has anyone else had this problem and if so, how did you fix it?
Thanks!
