We switched to Vodafone a couple of months ago and while the service is fine, the router supplied by them is distinctly patchy. I’ve got a fair number of internet connected devices in my house (somewhere around 80-ish) and I suspect that the domestic-grade router is having a hard time with it. Due to the layout of the house, the wifi is disabled on the ISP router and wifi is provided by a series of netgear extenders scattered around the house. These are all hard wired (the house is fully cat6), but again, these are less than stable, often needing to be kicked when they stop accepting connections.
I’ve decided that enough’s enough and I need to sort this lot out properly, so I’m in the market for a new router (should offer both VDSL2 and ethernet WAN connections as I’d like future flexibility, but built-in wifi not needed), as well as a decent set of wifi APs. They don’t need to be mesh, as I’d prefer that they are hard-wired back to the switch, but they should be decent quality, and ideally be reasonably future proof.
I don’t mind if this lot is part of an integrated system, or if the router and wifi APs are supplied separately. So, Singletrack, what can you recommend?
(Note: I’m an IT professional, albeit not working with consumer-grade kit, so “excessive complexity” isn’t a problem and, honestly, will probably be desirable as it means it’ll offer flexibility for the future!)
