Recommend me some disc brakes
Viewing 13 posts - 1 through 13 (of 13 total)
  • Recommend me some disc brakes
  • After a set of stoppers for a new bike, for xc and messing around on ( i will not say hardcore hardtail i just cant do it) got 08 XTs on the full suss but fed up with sticking pistons and find them slightly underpowered.
    Premier Icon turneround
    Subscriber
    formula k24's….
    foxyrider
    Member
    not sure these would fit 😉
    Premier Icon nickc
    Subscriber
    I'm surprised about your XT normally they're ultra reliable brakes. TBH it doesn't matter which ones you choose, they're all more or less the same on power, I'd say what ever your price point is you'll probably end up with decent ones.
    Pick a colour you like?
    Premier Icon zbonty
    Subscriber
    Current XT all the way
    Elixirs, CR's if you can stretch to it.
    Premier Icon chakaping
    Subscriber
    I'm surprised you don't like the XTs too, best all-rounder I've tried – and very powerful.
    SLX are very nearly as good too, amazing performance with 203mm discs on my very heavy Big Hit in the Alps the other week.
    Dango
    Member
    08/09 XT's, good here too, better than similar priced brakes I own
    ahwiles
    Member
    one of the reasons i like shimano brakes is that they use mineral oil, which is a lubricant, and i've never had a problem with stuck pistons.
    Dot fluid is hydro-phobic/phillic..?… sticky.
    i've got 4 bikes worth of Avid/Hayes/hope/hope brakes left gathering dust, no amount of tlc will keep the pistons free-moving, but i've never had a single problem on my ever-growing fleet of shimano brakes.
    my commuter is going shimano next pay-day, and that'll be ANOTHER set of siezed hayes being abandoned.
    SLX are my current favourites, i'm stunned by how cheap they are. Powerfull, but not grabby, very controlable.
    are your XT's the older 4-pots? my best guess is that there are more gaps for grit to get stuck in…?
    If thats the case, dont suppose you have any G2 rotors spare? 😉
    Hope all the way. I've got ancient C2s never seized,or let me down despite using regular dot brake fluid. A riding buddy has just flogged his XTR brakes and replaced them with Hopes.
    Also,Hope after sales care is legendary. Ask anybody that was saved by them at the Mega.
    Hope. Mine get an annual service and never let me down. Clean and lube pistons, new pads bleed thru. You need to change dot fluid every year or so.
    rolfharris
    Member
    I'd say get your XTs professionally looked at- all the ones I've used have felt wonderful, and would say they're probably the best brakes out there now.
The topic ‘Recommend me some disc brakes’ is closed to new replies.
