increase the compression damping.
It’s the R model so rebound adjust only, is that correct OP?
First stop is stick some (a lot) of spacers in the shock to add bottom out resistance.
If that’s not adequate, you could either get the shock tuned by a specialist so it has more compression damping, or you could upgrade to a more adjustable shock (air or coil).
I’d suggest the Cane Creek Kitsuma shocks, if they’d fit the frame in terms of clearance, as they have a very damped feel and tend to be a bit more affordable than the other high-end options like Ohlins, EXT or Fox.
Or the full monty option could be an Ohlins coil shock with a progressive spring, they are even more damped and the progressive spring adds loads of support.
