My new bike has Aeffecr R cinch cranks.
I removed them to fit an oval chain ring. No problems, I put everything back on in the order it was fired, with the instructions on their product page
Now mine seem to have an extra nds spacer (it is a wider superboost chain line and a 143.5mm spindle, so I’m told) and what appears to be a self extracting style bolt under a cap to pull off the drive side when uninstalling. All fine I guess, but slightly different to what’s shown on the link above.
What puzzles me is that it appears that you just tighten them up against the bearing. There’s no preload collar, just whack them on and do then up pretty tight. Surely this is going to put excess binding on the bearings.
Older cinch, SRAM dub, Shimano all have some way of adjusting preload during installation. I can’t help feeling what I’ve got is going to either accelerate BB wear or run the risk of excess play if I try and don’t tighten them so tight.
Any experience with these?
