My brother in law recently bought a Cube Ltd Pro. The bike has what I would call pseudo internal cabling. The cables go into the down tube just behind the head tube, then reemerge just in front of the BB from what looks like an externally welded on plate. The routing to both derailleurs is under the BB with a conventional cable guide thingy screwed into the BB.
His front derailleur cable has exploded, with the inner shattering out through the outer. I am pretty sure this has been because the derailleur cables are both routed to go down the same side of the head tube as the shifter, and so has put an unnecessarily tight bend in the cables.
I think I would re-route the cable to run around the head tube on both sides, but this will mean the exposed outers crossing somewhere on the downtube – I doubt this will be a problem, but can anyone advise?
I think the best shifting will be achieved by having a nicer bend in the outers and crossing the exposed cables, but if anyone knows different, please give us a shout.
