Home Forums Bike Forum PSA Worx Hydroshot £90
Viewing 40 posts - 1 through 40 (of 49 total)
  • PSA Worx Hydroshot £90
  • honourablegeorge
    nwgiles
    go on give us a clue where…
    grim168
    Click pic
    honourablegeorge
    Hmm – the preview pic thing is broken for me too – try this link
    bruneep
    Click pic
    that works
    dc1988
    Picture link works for me, good price and it’s the time of year when an after ride bike clean is more likely to be necessary
    davros
    Great deal. Mine has started running rough after 4 or 5 years so I took it apart to try to fix. I suspect it’s the pump which is a sealed part but unfortunately worx said they didn’t have it as a replacement part. It still works but just sounds ropey. When it dies I’ll buy a new one.
    bobodaclown
    Good deal that, they are good!
    I picked one up a couple of years ago the full kit as an ‘amazon warehouse’ deal for about £95.
    Kryton57
    Timely PSA thanks, the full kit on the same page was only £20 more. Ordered.
    honourablegeorge
    Yeah, I was considering the full kit, but I just got the unit and the short lance, it will live in the car. There’s a lovely rock-filtered pool of water by the carpark at my local trail I can use as a water source. Picture a Timotei advert, but in a cold, damp forest with a muddy bike and a scruffy middle aged fella.
    thegeneralist
    There’s a lovely rock-filtered pool of water by the carpark at my local trail which the outwash from cleaning my bike can drain into. A lovely rainbow hued film of rinsed chain oil delicately shimmers across the surface once I’ve finished. You can see the little waterskaters sink in when the oil reaches them and eliminates the surface tension.
    Not judging by the way. I’m just as bad.
    Kryton57
    Lol, well our garage at the back of our house opens to a private car park on route the next street along for access, so this means I can use the bucket to collect rainwater from the water butts at the end of the garden and wash the cars/bikes away from the house. Convienently there is a large storm drain with grid cover right in front of my garage door for the excess water to go.
    Hence, the remote washer is perfectly justified!
    kuman
    Silly question, would all karcher attachments work with this ?
    dangeourbrain
    Anyone tried the cheap Chinese ones Circa £50 on amazon
    Not sure how much use it would see – I’ve got a mobi thing at the moment but it rarely gets used because I forget it. In theory one of these could live in the car but even then I’m not sure it would be used as much but ballast for the car.
    JAG
    Another option but this one’s only £12.98
    Portable Pressure Washer
    JAG
    Oh the irony, there’s a thread over on the “Chat Forum” asking “Is the UK a rich country?”
    dangeourbrain
    I assumed that was a parody thread, that or some sort of reception class homework the parent needs help with
    honourablegeorge
    thegeneralist
    I may have oversold it with the Timotei reference, it’s more “a bit of a drain which isn’t full of sludge and leaves”
    stumpy01
    If you want to carry water & will generally be using it when getting back to the car, CRC have a good deal on the Mobi Pressure Washer.
    It’s showing here at £69 but when I clicked the link it was actually only £50. Bargain, (so long as you are with your car). I’ve got an original Dirtworker (the yellow one) that must be 15 years old now & stil going strong.
    Link here:
    https://singletrackworld.com/wp-content/uploads/2022/11/cheap-things-tuesday-006/
    clownfist
    The Ryobi brushless one is good too
    razorrazoo
    Top tip on the Worx.  Cable tie a fishing weight to the submersed end of the hose, the end has a habit of floating to the top of the water source and taking in air and this solves the issue nicely.
    reluctantwrinkly
    Daft question maybe but how does it compare to a mains pressure washer, would it blast algae off paving slabs for instance?
    johnnystorm
    @reluctantwrinkly
    You’ll be very disappointed if you buy one for blasting patios.
    honourablegeorge
    The one I linked is a lower power one, they do a brushless version with more oomph, and certainly advertise it for patio cleaning, but if your algae is anything like mine, you want a proper mains one
    reluctantwrinkly
    Ok so basically a pumped up hose that stands less chance of damaging bearings if used carefully
    I have a full sized one but is a pita to set up for a quick blast. Anyone know if the basic and full kit have the same charger?
    bikesandboots
    Alternatively, a couple of M14 nuts.
    dickie
    I went for the Ryobi at £140 that came with a ’12 tools of xmas’ free tool offer, so got a £70 leaf blower free, which I wanted anyway.
    Can also dry the bikes post wash!!
    cp
    I’m very tempted by the same deal.
    dangeourbrain
    Ohhh. Any idea on cross compatability of ryobi batteries. I do not need another brand of battery and charger…
    Tracey
    We bought a Hydroshot back in 2017 to keep in the camper to use when we were away but more specifically at race events. It works very well
    Its still going strong and we have used water from rivers, streams, lakes and ponds all over the UK and Europe.
    We can do 4 bikes easily on a full battery. We bought the impact driver and drill cheap and they are also kept in the van. They all slide away under a ledge in the back
    Also used it as a makeshift shower unit with the hose in a mountain stream in the Alps.
    If I was to buy one again it would be the Ryobi one on the back of having a lot of their other tools but that wasnt available again
    dangeourbrain
    They say up there it’s not strong enough for one’s patio slabs but I imagine it’s rather too strong for one’s slats.
    Tracey
    Low power setting and wide angle jet. Worked like a power shower but mountain water is very cold
    ta11pau1
    I think the lance has a ‘dog shower’ mode too which would work.
    I’ve got the more powerful brushless version and it does put out a fair bit more water with a bit more power – not quite a full mains power washer but not that far off. I’ll happily wash my big estate car with it.
    dangeourbrain
    Wide angle? Wide angle? You leave my weight out of this!
    squirrelking
    Maybe on a person, not on my dog.
    vinnyeh
    Before I send mine back as dead on arrival- there’s nothing that needs to be removed/switched  etc before use is there? Charged battery, connected hose and lance, can hear the motor, but there’s no action. Can’t feel any suction at the bottom or pressure at the top, no water being sucked in the hose.
    Any thoughts?
    Tracey
    If you can try connecting it to a hosepipe
    mahalo
    great bitta kit… its certainly not a pressure washer, it has no more oompf than my normal garden hose so dont use it at home (except as a dog shower with a bucket of warm water) but its class for washing bikes off before they go in the van if theres a river or stream handy! i have a dodgy battery though, could do with replacing it…
    davros
    Vinny, check the hose has properly clicked into place. If not it will draw in air. Can you feel any suction with the hose not attached? Worth double checking before sending it back!
    vinnyeh
    Couldn’t feel any suction at all, but followed Tracey’s suggestion, attached it to the garden hose and worked fine, so tried again with the bucket and hose and all was good. Not sure why, maybe the pump needed priming for the first use?
