Protecting lower headset bearings
Viewing 16 posts - 1 through 16 (of 16 total)
  • Protecting lower headset bearings
  • alongo
    Member
    Riding a gravel bike on and off road with different wheelsets, obviously at this time of year it gets pretty dirty. I am not using mudguards as I feel they would get clogged up with mud riding off road.The bike is quite new and I don’t mind cleaning it afterwards, however , I am starting to think the lower headset bearing is a bit open to all that’s thrown at it , I haven’t dropped the forks out yet, will do after weekend ride.
    Does anyone have any ideas or suggestions on what could be used to protect the bearing?
    Premier Icon weeksy
    Subscriber
    Can’t you just use a shorty MTB one like an enduro guard?
    Premier Icon cynic-al
    Subscriber
    A section of inner tube will seal it up well, but modern headsets are much better sealed than old ones
    endomick
    Member
    Better headset with rubber seal on the crown race or just buy the crown race with seal if compatible or old skool neoprene velcro thingy, then take off after ride to clean it.
    dovebiker
    Member
    1. Pop bearing seal and pack with marine grease
    2. Anything to keep spray off is a good idea e.g. cut-down Enduro guard
    claudie
    Member
    Cynic-al, really like the inner tube idea but does it rub the paint off the frame when the forks twist?
    tjagain
    Member
    mudguards are the answer
    Premier Icon rone
    Subscriber
    Is it worth being concerned? They’re about 7 quid.
    I ride all through winter off road (and commute) and I usually get through one bearing about every 9 months.
    Subscriber
    Claudie it won’t move against the frame/cup, just have it extend a few mm below the gap between crown race and cup, it will do its job.
    No need for mudguards.
    greeny30
    Member
    Innertube is a bad idea, any grit gets in it’ll stay in and cause damage, hope or superstar lower cup with the extra outer seal.
    Premier Icon andybrad
    Subscriber
    pop seal out and fill with marine grease.
    Premier Icon DezB
    Subscriber
    My new(ish: 2015) bike came with a Cane Creek headset and after a few grotty rides the bearings (or is at a bearing, singular?) seized. So, personally, I think headset bearings are as they ever were. I replaced them with Ritchey bearing(s) from CRC and they’ve lasted better.
    The bottom race on my old Yeti frame, which was in use for about 6 years in all conditions, is still smooth as new. So it all depends on the bearing(s). This one was a Race Face headset.
    globalti
    Member
    Bikes are designed for California not Britain.
    Subscriber
    i think more likely they are built to a cost and weight. Adding extra seals adds little benefit for the seller.
    Subscriber
    Greeny30 incorrect – I have done this and is works well, grit or water don’t get in.
    I don’t bother these days as sealing is good enough (it was 90s when this was a thing) (and I am mostly road riding with mudguards in the winter).
