Have been trying to convert a bike to tubeless, both the rims and the tyres are tubeless ready although it doesn’t seem to be the bead that’s causing a problem but where the tyre’s been punctured before.
I didn’t think I’d ever had a really big puncture most of them were just small thorns but I just can’t seem to stop the old holes leaking … is this normal and are you best off using a new tyre when you try to convert to tubeless for the 1st time.
If I put less pressure in like 10 psi they’re not so bad and a “bigger hole” the leak seems to slow, I’ve tried leaving it like this overnight and turning the wheel so the solution gets into the holes but it won’t stop leaking and if I try and put more pressure in it’s like the partial seal breaks out.
The solution (Stan’s) seems really watery is this normal as well … just trying to figure out why it’s not working and sealing the holes … any help appreciated!!
