Moved into a new house this week and tonight the lights in one room have decided to play silly buggers. They are mains voltage GU10’s. When you flick the switch all the bulbs flash very dimly but don’t come on. It happens with the switches at either end of the room. I’m new to this type of light (always had the 12v type before) so am a bit stumped.
As there is no transformer I guess the only common part to all bulbs is the switches really. If one switch is knackered could it effect the circuit even if you use the other switch? I guess it could but I’m very clueless.
Here are a couple of videos, in which you can hear me flick the switch and you should be able to see the dim flash.
https://dl.dropbox.com/u/34675823/bulbs1.MOV
https://dl.dropbox.com/u/34675823/bulbs2.MOV
