How long are you likely to be using these tools for in one go?
If you get a tool with a couple of batteries and a quick charger then as long as you get enough life out of a battery that the other one can recharge ready to be used then mains isn’t needed (you’ll get no more power from a mains adapter).
So if you can get, say, 40 minutes ‘working time’ (this is not 40 minutes of continuous drilling, it includes thinking, measuring, marking etc) from a single charge and have a 40 minute charger the next battery will be ready to use by the time the first is discharged (and so on).
