I have read lots about positive ventilation on Singletrack and other forums and I am just about to fit a Nuair drymaster in our house to help sort out condensation on the windows and damp in the corners etc. I can’t find nearly as much information about the units that are designed to work if you don’t have a loft space to draw the air in from. My sister lives in a ground floor flat of a stone built house with very thick walls. They have a general damp problem with damp behind furniture and in wardrobes etc. In general areas where their is little air flow, there is also a slight damp smell to the house when it has been locked up for a while. They have had a company around that have suggested to fit a Atmos wall mounted ventilation unit with heater that will then be ducted to blow into the hall way that is the central point to the apartment, all rooms lead off it. They have also suggested fitting 3 cyclone 7 extractor fans. One in the bathroom which currently doesn’t have anything, one in the en suite that has a unit but it is badly plumbed and one in the Kitchen. The cyclone 7 is a wall mounted fan where I have always favored an inline fan for shifting more air, it runs all the time in a trickle mode and then detects humidity to run at full power when needed. the quote is just £2900 which seems pretty high to me but there are 2 thick stone walls to cut hole through
Any experience of fitting PIV to a flat greatly received and also any experience of Envirovent and there products.
They are located just south of Bristol in Cleavdon so any recommendations for other companies or people to approach greatly received.
