Hey boring plumbing woes I’m afraid…
I have a 3 story mid 90s house with 8mm microbore its been slowly dying over the years and I’ve replaced what I could afford at different times… but now downstairs has packed up and the first floor is only “warm”. Upstairs is still hot though.
The first floor has new rads but that didnt make much difference.
I want to know if I replace the 8mm pipe on the first 2 floors if I’m likely to get into any other trouble… ie stop the top floor working?
I cant afford the time to do all 3 floors at the moment but my plan is to simply run 15mm plastic to replace the 8mm. The main feed is 20 or 22mm (off the top of my head) so think thats fine.
edit – whats the best way to cut plasterboard from the walls? (that makes as little mess as possible)
Thanks
