Plenty out there that is better than Shimano with fitting that doesn’t require extra precise fitting.
Haha, is that some kind of a joke, right?
Like a self extracting spline system that requires so much torque to do up properly you are in danger of not just stripping the thread but shearing the bolt in half? That’s definitely a ‘better’ system.
E13 cranks. Crap mounting system, BB life measure in minutes & lots of silly bits needed to fit them.
Raceface cranks. Crap self extracting bolt system, BB life comparable to E13 & that’s before they thought it would be a good idea to use smaller bearings due to a 30mm axle. Look nice though.
Hope. Probably the best of all 3, look a bit crap, weigh a tonne.
Buy Shimano. They just work. XTR’s are just as light as XX1. Might not be as light as Next SL’s but who cares when you replace the BB every 3 months and the pedal falls out of the crank because they (still) haven’t mastered the bonding process.
