After a bit of advice on behalf of a friend.
He lives in and owns a first floor flat built about four years ago. When built the ground floor was designed to be for business use (two units) and is owned by the leaseholder. The leaseholder was unable to rent these units and last year was granted planning permission for conversion to four studio flats.
The work was started a couple of months back. Although unhappy about the noise, he works from home) and a couple of early starts all was progressing until this week when he tried to open his front door and was unable too..
Having managed to eventually pull it open. He realised that the builders have removed a section of wall to extend the new flats below the walkway which is the access to his flat. This is a section of supporting wall for his flat and the flat above (can’t remember if there is a flat above that one).
He has not had any notification that this would happen, the leaseholder assured him there was no structural work, a Party Wall agreement was never offered and Building Control are not interested, the inspections are being done by a private firm.
So over to you lot, any suggestions?
