In general speedometers will read slightly higher than actual road speed.
However, cameras will only trigger over a certain slightly-higher speed in any case, so you have a little leeway. This means your actual road speed can vary slightly without being penalised. That means you don’t have to be staring at your speedo as you are driving along “just in case”. And if you can’t control your speed to +/- 5mph of the speed limit without looking at your speedo constantly then you need to pay a bit more attention!
Damn! My sat nav is 35mph when my speedo is indicating 30mph.
I usually drive within the sat nav and speedo range but just want to be absolutely sure because it will be too late if I get a ticket.
Still trying to drive within the limit of +/- 5mph without looking at speedo or sat nav. aarrggghhh … 😐
jam bo – Member
There are a number of areas that are moving to zero-tolerance and issuing tickets for anything over the limit. Devon an Cornwall is one of these, as is South Wales.
Yes, that is my concerned because with a zero-tolerance I would be in trouble if I drive within +/- 5mph.
I think there are plenty of cameras already in the North East … 😯
