I’m not the most patient mechanic, but I get by. My general rule is to only fix stuff I know how to fix when I have sufficient time to fix it. I stick to my rules and (generally) nothing expensive gets broken. (we’ll put the cutting of the integrated seatpost too short for another thread I think).
But this time, with 10 minutes till I have to leave to pick up micro-likes_food from school I decide to replace the bearings in my front wheel… what was I thinking?
End caps off, easy a 5 mm allen key in each one and off they spin. Mmmm, I’m faced with a new situation, a threaded axle with 10mm allen key bolted ends (if that even makes sense). ‘Ahah’ I think, two 10mm allen keys are needed to undo the axle by turning them in opposite directions. What was I thinking!
Cue some excessive force and a knackered axle. The soft aluminium end of the axle has splayed out and split.
If anyone can help me a) get the axle out and b) find a new one I’d be very grateful.
Yes I have contacted On One. They don’t have spare axles and say it should slide out (and my rubber mallet says it won’t, and my rubber mallet has never been wrong about things not sliding out before!)
