I’m trying to remove the shock from a 2006 stmpy fsr frame, and either I’m daft or Specialized have made a right weird frame…
There’s a single bolt, which passes through the linkage on one side, through what seems to be a steel axle that holds the shock eyelet in place, and then threads into the other side of the linkage. With the bolt removed I’m left with an axle that can only come out from one side (as the other is threaded), but with nothing to get any purchase to tap it out.
I have no clue. Does anyone on here have the same frame, and would they be willing to give up the magical secret of specialized shock removal..?
Thanks!
Huw
