It’s only the same effect as draining and replacing the oil, I’d not be too concerned. One start over a lifetime of thousands won’t harm it, it’ll be full in a few seconds.
I had a job in the hot test facility at Dagenham engine plant 2 litre petrol engine line once. Every single engine had the nuts revved off it on starting, to prime the pumps and get the fluids moving round. Completely dry bearings, bores, cams etc. If after 15 seconds no oil pressure, try again. After the second failure, check there was any oil in it. Surprisingly often there wasn’t. They almost always passed the tests after being filled up, and off to a customer, (with 30-40 seconds of totally dry, high speed thrashing). 😮
