Seat tube twice. A bmx clamp.
Yeh I know a reverb or ks won’t work.
Carbon paste won’t help it’s not a slipping issue it’s a creaking issue from a second crack that can’t be welded. With the double clamp the crack is supported and the lower clamp part is below the crack completely. Can’t be welded or then you can’t get the clamp over the weld.
Rides spot on with the double clamp and a rigid Seat post. I’ll just ride it with the fixed post if I have to but thought I’d see if anyone knows if any of the older manual ones are a bit more industrial… I’ve got no experience of them hence asking if anyone knows of one that can take a bit more umph on the frame clamp?
