I suspect it depends on the casing and how hard / smooth your mate rides. Schwalbe changed all the names recently, but whatever the basic one is, erm, Super Ground I think, is a bit fragile on rocky stuff at full sus speeds. I nailed a basic Rock Razor in the Peak first ride out without being super aggressive. The Super Trail version, which has tougher sidewalls without being a full-on downhill casing, is more robust ime.
Your other option might be an instert, Rimpact or similar.
You can likely fix the tyre with mushroom patches btw.
