Viewing 13 posts - 41 through 53 (of 53 total)
  • Nissan Leaf – Owners experiences
  • Premier Icon v8ninety
    Subscriber
    I think in reality, a 40 mile range would suit a lot of people for a lot of the time.
    Perfect second car territory; let’s hope there’s a glut and no one wants them to bring residuals right down 😎👍🏼
    ~£27K new, ~£5K with 74,000 miles. Not as bad depreciation as some but then for £5K you have a car that only does 40 miles.
    My thoughts were to wait a couple of years for reconditioned battery prices to drop. They were ~£16K in 2014 and ~£6,500 2019. Once they drop another couple of £K I can replace mine and suddenly get a 100 mile range EV (assuming upgrade to 30KW) for £3-4K.
    Cheap second vehicle. You just need to think of batteries as consumables and spread the cost over the miles. Suddenly they are fractions of a penny per mile and so the cost is almost irrelevant
    B.A.Nana
    Member
    👍 I heard there are companies who will part ex a recon battery for your battery or recon your battery as it’s only worn pouches or modules that need replacing.
    To Do
    1)Change to Octopus Energy
    2)Work out how to do timed charging
    3)Give up on Nissan Connect
    Have you got a home charger yet?
    1)I’m on Octopus Agile. You go on a interim tariff until either you get a smart meter installed or they set up communication with your secure smart meter. It can take about 3 months from supplier switch to meter install to going onto your chosen tariff (Agile or Go). To cover the interim tariff cost make sure you get a referral code from someone (i.e. me), the £50 bonus will cover the slightly high tariff cost for that interim 3 months(ish)
    2) is that ‘working out timed charging’ from a menu in the car? If you go onto Agile tariff then you are best having a Ohme wall charger (or Zappi) or untethered wall charger with Ohme cable. Then the charger(or ohme cable) will cherry pick the cheapest 1/2 hr Agile tariffs for you.
    So in this example it might charge 00.30-01.00, 02.30-03.00 and 03.30-05.00 to get the cheapest cost for you up to how full you want the battery.
    3) is Nissan connect that bad? (I’d heard as such)
    Yes there are. You give them you battery and£6,500 and they fix the worn pouches and return it to you fully working. At the moment there are very few such companies but I see the market expanding in the next couple of years as more and more 8-10 year old Leafs are mechanically fine but need batteries.
    I would love a referral code from you for Octopus please.
    The charging for the moment is through a 3 pin as I dont want to invest in a wall charger yet. I am thinking that I will get a tethered charger but as the Leaf is Type 1 that is a bad investment. If I stay electric, which I guess we will all be forced to soon, then I will get a tethered charger to fit the new car. I will use the in car timer to get the cheap rates from the GO tariff for the moment.
    retro83
    Member
    WorldClassAccident
    Member
    I read that Nissan were doing refurbed packs for roughly £3K
    eta- £2K but in Japan https://www.carsuk.net/cost-of-replacing-the-nissan-leafs-batteries-drops-90-in-seven-years/
    Premier Icon scuttler
    Subscriber
    Seat belts required industrial cleaner and a steam gun to remove the mould an curry stains.
    Dirty EV bastards.
    B.A.Nana
    Member
    Thank you very much WCA (I’ve PM’d you my code).
    Re tethered chargers, My understanding is that you would only need to get the cable changed over from type1 to type2, so it wouldn’t require a whole new charger unit (this might differ depending on the brand of unit ie Ohme?? not sure). The other interim option is to get a commando socket installed (presumably the electrics to the commando socket could then be used for the new charger unit?). Only other thing I can think of is if you have any intention of trying Agile tariff then it works best with a charger that can work with Agile (I think right now that’s Ohme or Zappi, I would imagine more will be wanting to get onboard) as in having the tech to cherry pick the cheapest times as per the example above.
    Premier Icon simon_g
    Subscriber
    While all this battery swap stuff is possible, I think a lot of these early Leafs (and probably much of the generations after) will do that runabout job on their degraded batteries, changing hands for less and less money to people that need less and less range. Just the labour in doing a battery swap is quite pricey, let alone the pack, and you’ll never get that back. 30-40 miles is absolutely fine for a lot of people as a second car for running kids about, shopping, etc.
    We got an untethered charge point a couple of years ago and used to just leave the cable attached when we were charging the PHEV every day (run it through a padlock/hasp if you’re worried about theft). These days I only need to do once a week so it lives in the boot. Cars generally come with the right cable – you need your own for public non-rapid charging – so any future one will work fine with your untethered point. They’ve already got more expensive to install recently and I can only see that getting more expensive if the grant get squeezed more.
    B.A.Nana
    Member
    I’m the same as simon-g, I’ve got an untethered Rolec (none smart) and recently bought an Ohme smart cable through Octopus Energy. Only about 12 months ago Rolec website was quoting £149 for a straightforward untethered charger install (with grant), then it went to £249 for a smart charger install, now it’s £295.
    Premier Icon rone
    Subscriber
    Leafs quite decent on lease at the moment.
    Don’t overlook EDFs tarrif too.
    Slightly more expensive than the others but available over much better time periods.
    I agree about 30 miles bring fine for what I use the car for. I have two others for fun or longer journeys. This is also why I am not getting a charger yet.
    The car I bought is a cheap experiment I want to run for a year or so to see what I really need
    My thoughts about tethered is that if I don’t get one then I will just leave the cable in anyway for convenience (and need s spare for the car)
    Tallpaul
    Member
    Do the degraded batteries still require the same time to recharge? i.e. does the ppm charging cost increase as battery life decreases?
    Premier Icon winston
    Subscriber
    “According to the EV doubters at Top Gear, that’s the problem with the Leaf, when they’re getting on a bit the range falls to 35-40 real world miles and nobody wants them, hence very cheap to buy. I guess that would seem very limiting to a lot of people for an only car, but you’ve got a few.”
    Problem is its a V1 and they have the worst battery degredation.
    Mine is a V2 and getting on for 6 years old. Battery is still at 89% and it was at 85% when I bought it!  Basically it was ‘stored’ on a drive by an old lady for 2 years where it did less than 4k miles and was left plugged in the rest of the time. I bought it and have driven it like it was stolen for the last 3.5 years. I’ve put 40k on it and charged it hundreds and hundreds of times. I’ve carried bikes  and kayaks on the roof and loaded it down with people and kit.
    Its filthy and the alloys are scratched but the battery is in far ruder health than when I got it. I reckon if I drove like miss daisy I’d get 75- 80 miles out of it.
