Brute force: If its not working, your not using enough of it
as long as your sure your turning the **** the right way (and if your selling bikes you must faaiiirly sure) then get your rage on at it.
stick the crank (off the bike, into a bit of scaffolding to give you loads of leverage, and similar with the other end.
i had a stuck BB a few years back, same deal: steel/alloy chemical weld.
I went at it with a blow torch, soaked the bottom half of the bike in parrafin for days, nothing worked.
bike shop put the frame in a big sturdy stand, and got out their secret weapon: a BB tool with a 2.5m lever on it.
one firm shove, and out it span. Threads were perfect, no worries to date.
