Mudhugger still guard of choice?
  • This topic has 46 replies, 19 voices, and was last updated 1 year ago by  iainc.
Viewing 7 posts - 41 through 47 (of 47 total)
  • Mudhugger still guard of choice?
  • geex
    Member
    Take a pic of your fitting @Onzadog.
    particualrly what holes you mounted it by and a side on to see the angle of the guard against the wheel and position/angle the tabs sit against the lower legs
    It fits fine with a Boost Lyrik
    Onzadog
    Member
    It all looked fine at first. I used the centre line of holes and pushed out rows 2 and 4.
    Set the legs so that the clearance front and rear was equal. All was well until the last 10mm of travel.
    I even had self amalagamating tape around the arch which should set it a little lower than normal and make things slightly better.
    Onzadog
    Member
    Both forks I tried it on, when you bottom the fork out, the crown comes a few millimetres lower than the arch.
    I think it just needs some sort of spacer or packing material.
    Premier Icon kcal
    Subscriber
    cheers Iain. will do if that’s OK.
    Premier Icon iainc
    Subscriber
    kcal, sold them yesterday, sorry.
    Premier Icon kcal
    Subscriber
    hey iain – no worries — just realised they were 650 ones anyway!    next time you’re up North / Aviemore area could hook up for a spin, I’m a bit further north (Moray)…
    Premier Icon iainc
    Subscriber
    ^^^ sounds a plan !
The topic ‘Mudhugger still guard of choice?’ is closed to new replies.
