Shimano are cheap and reliable. If you want something prettier anything which over cams (eg goes loose-tight-slightly looser) with a proper seat and no shim should be fine (except hope unless they’ve fixed the threads being made of cheese).
I got a crank brothers split lever one cheap as chips years ago and it’s been bombproof but seem to recall them being seriously pricey normally.
Dt rws works very well but really doesn’t bring much to the party for the cost. Don’t read too much into a couple of YouTube videos and comments, everything fails now and again.
Clamping force on your qr isn’t the problem, you should be able to get a lot more force on the qr than you’d ever want, the issue with cheap qr is they tend to have shims which fail or move or they don’t over cam. (or even with good qr, people lock them down facing the triangle so the frame prevents it being closed properly as it won’t push beyond “flat”.
