AGM batteries can be a bit problematic if they become fully discharged, as then then either need a high voltage to force a charge into them to start charging quickly, or a prolonged lower voltage charge. Usually putting them on an unregulated charger overnight will recover them well enough to become serviceable again.
I say unregulated, because digital staged chargers typically only work on voltage, so you connect a flat battery, it enters constant current mode, voltage rises quickly due to the battery having high internal resistance, it reaches the charge cut-off voltage, the charger then thinks the battery is charged, so it then drops to trickle charge mode, which the voltage generally isn’t high enough to force the battery to start charging.
AGMs are not an ideal drop in replacement for a conventional lead acid battery, but they can work well. The major benefit of AGM is they accept charge far faster than wet batteries, however that means on a non-smart charge system, they will push alternators to their limit.
Without a smart charging system, jump start a wet battery system and the alternator voltage will quite quickly rise to above 14V and the battery will gradually accept charge. With an AGM battery, the alternator voltage won’t rise until the battery is charged. I’ve seen AGM battery voltages sit below 13V while only gradually creeping up with the alternator belt screeching and the alternator itself starting to smoulder after being jump started because they’re absorbing that much charge the alternator is being pushed beyond it’s limit.
Smart charging/battery monitoring systems will handle those conditions, and ensure the alternator is never pushed any harder than it needs to be.
