- This topic has 58 replies, 44 voices, and was last updated 1 year ago by fossy.
most reliable/durable gearing set up.
honourablegeorgeFull Member
Chain does have a quicklink
Shifter does allow a double downshift
https://r2-bike.com/SHIMANO-Deore-XT-Linkglide-Shifter-SL-M8130-11-speed-I-Spec-EV
onewheelgoodFull MemberMy 2014 XTC has SLX 2×10. I recently had to replace chain, rings, cassette. Availability of these parts was pretty poor. Not one supplier had both rings, although cassettes were slightly more common. It looked like my options would have been even worse on a higher end groupset. So my advice, if you want 10-speed, would be to go for something that is still in production like Microshift, or maybe Box 11-speed.
nickcFull MemberThe obvious answer is a belt-drive Rohloff
Wasn’t there a guy on here wo was forever stripping his belt drive with trapped stones and the like? Although I seem to remember he was a bit of a destroyer of kit?
BigJohnFull MemberI know its heretical to say so but my NX 1×12 11-50 setup hasn’t missed a beat. I bought a Giant Trance in November 2019 with it on, and I budgeted to change it for something proper when it started playing up. Well, it hasn’t, and I ride it on a regular basis. All I’ve done is changed the chain about a year ago just as a precaution.
devashFree MemberI ran XT M8000 11 speed for 6 years before swapping to SRAM GX 12 speed when I bought my new bike in December. Was totally bombproof and did many 1,000’s of miles across two bikes.
The only issue was having to grease the clutch every 6 months or so, which was quite a fiddly job.
So far I’m having very few issues with the SRAM stuff and the chains seem to last longer. I think at some point I’ll swap out the GX cassette for an X01 or Garbaruk one piece job though.
keithbFull MemberBog standard 8 speed set up. Never needs tweaking, chains last forever, nothign seems to wear out and, when it does finaly wear, you can replace the entire drivetrain for about £50.
The biggest problem with it is that, as you never have to touch it, adjusters can seize up due to lack of use!
Or singlespeed….
stevextcFree MemberMy 2014 XTC has SLX 2×10. I recently had to replace chain, rings, cassette. Availability of these parts was pretty poor. Not one supplier had both rings, although cassettes were slightly more common. It looked like my options would have been even worse on a higher end groupset.
Make me a reasonable offer (at least equal to postage cost) if you want more chainrings. I’ll chuck in the XT front and shifter mech as well
ElShalimoFull Member@ton – Spa Cycles will have something 8 or 9sp for you. Give them a call
ayjaydoubleyouFull MemberChain does have a quicklink
Shifter does allow a double downshiftonly a double though. conventional XT allows 4.
onewheelgoodFull MemberMake me a reasonable offer (at least equal to postage cost) if you want more chainrings
Thanks for the offer but I think I’m sorted – found someone who had some Blackspire rings bought for a project but not used. Had to pay a bit more than postage though 😢
SannyFree MemberIn the spirit of recommending what you have, my Surly Ice Cream Truck’s drivetrain is well over 7 years old and still going strong. Surely steel rings ( the outer is now more smooth than pointy but still works), KMC chain, 11 – 36 SLX 10 speed cassette. The jacket wheels had a moment a few days back when the bearing sleeve moved in the jockey wheel but was soon encouraged back into its proper position.
That bike has done thousands of kilometres of riding and not just on the beach either.
By way of contrast, the 12 speed XT set up I had on a test e bike was 100% worn in less than three months.
I have a new outer ring, cassette and chain ready for the Truck when I can be bothered getting round to changing it. So I guess 2 x with steel rings is what gets my vote!
Sanny
chestercopperpotFree Member1×10 Shimano with Radcage, Sunrace wide range cassette (you can go all steel) has been the most bulletproof and best value setup I’ve had to date. Win win!
All my drivetrains take an absolute pasting and the mechs look battered after a few months riding.
I’ve found Shimano 11sp (XT and SLX) mech cages get bent out of shape far too easily for some reason!
snapsFree MemberRohloff on the winter offroad commuter, I get over 2000 miles out of a £8 PC1N chain.
Summer commuter has 2×10 XTR with Sunrace cassette – very reliable but I’d love a 10 speed cassette with a 10t cog to give me a better gear spread.
a11yFull Memberxg1150 cassette- all steel, pretty light, lasts for aaaaaages
The most reliable and faff free drivetrain I had was Sram GX 11 speed. Just did it’s thing and the all steel cassette just went on and on for ever.
with SRAM xg1150 cassette and SRAM chain. My cassette lasted 6 years with 3 chains
Continuing on the theme of durable gearing set up… 11-46t SLX cassette vs 10-42 SRAM XG-1150 cassette – which is more durable?
I suspect I know the answer but seeking reassurance that it’d be worth the additional expense (in the longterm) of buying an XD driver for my hub and swapping my worn out 11-46 SLX and 30t chainring setup, to a 10-42 XG-1150 and 28t steel chainring. My cassette, chainring and chain need replaced soon anyway and comments on the durability of the XG-1150 have piqued my interest.
I’ve compared gear ratios: SRAM 11-42 (with a 28t chainring) looses out marginally at the low end (18.9 vs 19.5 gear inches) and would gain a ‘faster’ high gear (79.4 vs 81.5). Slight weight saving and (IMO) a nicer spread of gears towards the top of the cassette with smaller gaps.
Is the SRAM XG-1150 that much more durable to make the change worthwhile?
ballsofcottonwoolFree MemberMy mates were breaking chains every ride when 9 speed came out and I was still on 8 speed. I only just switched from 8 to to 10 speed last year and the narrower chain seems just as durable ( I think they finally started using a stronger steel for the side plates), the increased cable pull of Dynasys means the shifting feels just as precise as 8speed did.
If always preferred Shimano to SRAM especialy at lower price points I’ve found although SRAM is lighter, but only because they use plastic rather than Shimano who use steel. SRAM stuff wears out more quickly as a result.
2×10 (40:28 11:32)is nice on my gravel bike for the extra range at the top end, but 1×10 with a tiny chainring(30T 11:42T) is fine on my MTB, I just coast above 20mph. Its great to not having the front derailleur that stops working when the parallelogram is stiffed with mud and stones.
misteralzFree MemberI build EVERYTHING 1×10 now, as after years of frequent meddling with 3×7 through to 2×10, 1×10 feels like the absolute sweet spot. Providing you use the right stuff, of course. Which is a PG1050 cassette, KMC chain, and XT M786 shifter and mech. Multiple shifts both ways is glorious, and the proper positive shift action just feels so well engineered. I hate sram shifters as I’m autistic and using my thumb for both up and downshifts is horrible. But their cassettes? Fab. I’ve got 6000km on one of them, and after a good clean it still looks new.
mattsccmFree MemberI am guessing that those suggesting 1 x 10 or 11 haven’t much to compare it with. Undoubtedly it can last fairly well if maintained but we all know that, quality being the same, the smaller the number of sprockets the longer it will last. It’s not the number but the implications. Best bet will be a 7 or 8 speed cassette with a short rear mech and a nice close double chainset. The short mech gives a better shift than a long one and it isn’t dangling in the crud like a long one. A front mech is the most fool proof moving part on a bike if you set it up properly. If you can’t then tough. Anything 1x gives a poor chain line as any bike chain runs and last best straight not bent. Ideally go for friction gear changing. Nothing to chose between down tube or bar end and thumb shifters are close behind.
Biggest snag is getting decent quality kit as that has dropped off in recnt years. A nice Dura Ace 8 speed mech in good nick will last for ever.
Best of all will be SS or fixed. The latter will even save on brake blocks.fossyFull MemberI am still running 8 speed 600/Ultegra and Dura Ace – just works. Also LX/XT on my old MTB that I use for commuting on the canal.
