• This topic has 12 replies, 11 voices, and was last updated 3 months ago by Pook.
Viewing 13 posts - 1 through 13 (of 13 total)
  • Middle class hipster knowledge
  • Premier Icon igm
    The metal cap and cage from a champagne bottle makes an excellent candle snuffer.
    Clearly not upper class knowledge as Jeeves would be using the antique silver one / one crafted from the regimental spoons uncle Geoffrey brought back from the first war / Boer war / Waterloo.
    Premier Icon oldmanmtb2
    Errmm you might need to get out more…
    Premier Icon Rubber_Buccaneer
    Why don’t you just blow them out? At your age you’ve had enough practice.  Or just turn the lights on
    Premier Icon sirromj
    This is so close to being a Viz Top Tip, but not close enough. 2/10.
    Premier Icon MoreCashThanDash
    Oof!
    Premier Icon thols2
    Proper hipster candles come with a snuffer included.
    Premier Icon tjagain
    I have a candle snuffer. Much better than blowing them out. You don’t get wax splatters ( I know you can put your hand behind the candle and blow them out that way but its not as good) and also it reduces / eliminates the smoking from the extinguished wick
    Its pretty basic stuff – using the correct tool for the job. 🙂
    Premier Icon FB-ATB
    Lick thumb & index finger, pinch the wick- candle out and no smoke.
    Premier Icon toby1
    Do modern day hipsters drink Champagne? A semi-sparkling pet nat maybe?
    Premier Icon thols2
    Proper hipsters drink kombucha for the probiotic benefits. It’s a very effective cure for constipation, if you want rapid weight loss, kombucha might be the miracle cure you’re looking for.
    Premier Icon andrewh
    I love that smell!
    And the one from the matches
    Premier Icon WorldClassAccident
    I have a candle snuffer but he is on holiday this week so I might try the champagne top instead. Thanks for the tip
    Premier Icon Pook
    You can also dashion them into a jolly little man raising his hat
