As I showed, geometry does not work. However trigonometry does:
Four applications of the Sin rule to find the lengths of the inner l1,l2,l3 and l4 from vertices and midpoints to the crossover, then the Cosine rule to find the distance across the triangle and finally the Sin rule again will get you to (excuse the lack of brackets:
Sinx = (Sin60/Sin50)(Sin10/Sin40)Sin50/Sqrt((Sin10Sin60/Sin40Sin50)^2 + (Sin20Sin50/Sin30Sin70)^2 – 2*(Sin10Sin60/Sin40Sin50)*(Sin20Sin50/Sin30Sin70)Cos50)
EDIT:
Here is the proof:
Denote the midpoint F and assume AB is 1
Then:
Sin rule 1: BF/Sin30 = 1/Sin50
Sin rule 2: BF/Sin130 = EF/Sin20 so EF = (Sin30/Sin50) * (Sin20/Sin130)
Repeat:
Sin rule 3: AF/Sin60 = 1/Sin50
Sin rule 4: DF/Sin10 = AF/Sin40 so DF = (Sin50/Sin50) * (Sin10/Sin40)
Now we have two sides of the inner triangle and the angle 50, so it’s cosine rule time
DE^2 = DF^2+EF^2-2*DF*EF*Cos50
that gives us the third side of that triangle so we can use the Sin rule one last time
Sin rule 5: DF/Sin50 = DE/Sinx
Hence Sinx = DE*Sin50/DF
back substitute for DE and DF and you should eventually get the solution above.
Simples?
