I’ve had a Garmin Edge for ages now but my usage has always been just a case of looking at routes after I’ve done them in the Garmin Training Centre/Google Earth. Now I’ve got a Suunto Ambit3 I figured some mapping software could be quite handy. The 2 things I am thinking of using it for are:
– planning routes
– working out the elevation gain/lost from my Edge routes! (the altimeter doesn’t work very well, I’ve lots of 20km high rides apparently)
I’ve been trying to work through free trials to get familiar with each as I’ve seen people suggest on stw. So far I’ve only looked at memory map. One thing I’ve noticed is the distinction between routes and tracks which I’ve seen mentioned elsewhere.
This doesn’t help with working out elevations from previous rides on my Edge as these come in as tracks, whilst I can see a profile I don’t seem to be able to get a total vert stat anywhere.
I’m a bit unsure what the process is in terms of route planning too, say for instance you were following some forestry track snaking its way up a valley you’d only put way points every so often at junctions/navigational areas but the amount of straightlining you’d do would mean that the distance/height gain on your route card might not truly reflect what you’re actually going to walk/run/ride. If you were to religously plot tortuous tracks you’re going to end up with tons of way points which will be a pain to follow! What do people do for this? I’m struggling to find any workflows as opposed to just instructions on what each button does!
Any help/suggestions much appreciated!
Mat
