- This topic has 134 replies, 43 voices, and was last updated 5 years ago by geex.
Manual madness
giantalkaliFree Member
My full sus is easier than my hardtail for some unknown reason
geexFree Memberit’s just different Juliens. on a full sus you have the suspension compression to overcome with the initial push through your legs being the main difference
If you’re used to always manualling a full sus you might actually find a hardtail more difficult.
ie. a lot of mtbers think BMXs are easier to manual and jump. they’re not. They’re actually much more difficult to hold a manual on and much more twitchy to jump as smaller body movements have more effect with the shorter wheelbase.
giantalkaliFree MemberCan someone post a vid of themselves doing this so we know who’s legit?
geexFree MemberI don’t care whether you think I’m legit. Nevermind know how to video myself
eastdllFree MemberTry this? https://www.ryanleech.com/manual-master-class/
I’m working my way through it.
maxtorqueFull MemberUnless you are an orangutan and ride an BMX, then your bikes effective top tube reach is going to be longer than your arms! (even more so these days with the long endurooooooo bikes) Hence, whilst still holding onto the bars, you CANNOT just move your body far enough backwards to get to the neutral balance point, where your CofG is precisely above the centre of the rear wheel.
The drop and back “L-shape” technique is taught to beginners because it separates the unweighting of the bike, from the push-forwards / stand-the-bike-up bit.
Take a look at this pic of a flat land manual:
Because your hands and arms, feet and lower legs are forwards (unless you want to let go of the bars and slip off the pedals, which you don’t!) then you need your hips some distance behind the rear wheel centre to get your “average” CofG precisely above the rear wheel centre. So unless you look like our aforementioned orangutan, the only way you are going to do that is to tilt the bike backwards around that rear wheel. Look at the angle of the top tube in that pic, we are talking about really quite a steep angle, and that feels odd at first (very odd to most people)
The “L” technique is not required or needed by riders who can manual or are ‘natural riders’, as they will have learnt how to move to achieve the correct position of their body above the angled bike, but for typical beginners i think it’s a very valid technique to help you learn how to get you and your bike into the correct position! The “drop your body” part unweights the bike on it’s suspension, bringing the BB upwards (modern bikes have low BB’s!) and the back bit makes you thrust the bike forwards with your legs even if you think you’re actually pushing yourself backwards! (in reality, the physics of momentum mean the absolute movement is ratiometrically divided by the ratio of your body mass to the bikes mass!).
I’d suggest that most people when learning (myself included) are most afraid of the loop out and off the back**, and fail to get the bike angled enough, which means they cannot ever move far enough backwards, which means they can never hold the manual! (and it also means a huge exaggerated motion is required to try, often leading to imbalance as the tipping point is reached, causing instability and generally resulting in either looping out or dropping the front) The Pros make entering a manual look smooth and minimal because they have perfected the entry!
Once you can regularly get the front up and get to, or slightly exceed the balance point, then ime, the next barrier is learning to not use your arms to try to maintain that balance. It’s all in the legs, but if the front comes up and back too far, then your brain is wired to try to pull on the arms to pull your body forwards. which, oh dear, just makes things worse (because you are heavier than your bike, so you just move the bike further upwards/backwards rather than move yourself forwards) Here, learning to drive your legs back and forth to move your hips in the right place is crucial. For me, this bit took the longest to learn, the instinct to pull on the bars was huge. What helped was to try to think about my hips as the point i wanted to control, thinking “hips forwards” and “hips backwards” which helped me attempt to get my instinctive muscle memory to use my legs and not arms.
** as humans, with our arms only really capable of swivelling forwards at our shoulders rather than backwards, we are much more balance sensitive to falling backwards, because we instinctively know we have no way to arrest a backwards fall. Try it, stand up, see how far you can lean forwards before you feel you are at risk, now try leaning backwards, for most people the angle is very different!)
howsyourdad1Free MemberYou could have practiced for 10 mins instead of reading that.
Joking!
bullandbladderFree MemberJust buy a Carrera. All the little shits round here seem to be permanently on the back wheel on theirs.
geexFree MemberTBF I’m with the little shits on this one. Having been one myself. Maybe still am.
giantalkaliFree Memberno idea if that link will work, but here’s me doing a manual with step by step instructions.
funkmasterpFull MemberPracticed again this morning and managed to get the front end up slightly before almost riding straight in to the canal. Think I’ll find a nice field or quiet road to practice on.
geexFree MemberCrocodiles in the canal are what’s needed. Should make you slightly more committed to looking ahead and keeping the bike straight. 😉
vickypeaFree MemberI would like to be able to do a manual but fear of crashing onto my back is stopping me from even practicing. I did a skills course recently, and the instructor lifted the front of my bike (while I stood on my pedals and moved my weight back) to give me a bit of confidence that the front has to go up a heck of a long way before you tip over backwards. I feel like if I could just man up and do it once, I’d be more confident at practicing it over and over. I might have a go on grass, as suggested above.
funkmasterpFull Membervickypea, I’m probably wrong but aren’t you in Macc? If so, we could pick a nice field and start the MMC (Macclesfield Manual Club) 👍🏼😀
vickypeaFree Memberfunkmasterp-
I’m in the Macclesfield area, maybe we can meet and practice being crap at manuals together 😀
vickypeaFree MemberHa ha, we made our posts suggesting the same thing at the same time!
mr Pea gets frustrated with me that I can’t do a manual, and then I shout that I understand in theory what to do, it’s being chicken that holds me back!
funkmasterpFull MemberCan he not teach us both, I can pay him with booze or teach him how to fall off his bike with style?
geexFree MemberI said this earlier in the tread. But I’ll say it again.
Actively practice going past the balance point and coming off the back.
*By all means do this on grass. But you’re not going to be landing on your back! Instil this thought in your mind before even attempting what I’m about to say:
Now. Here’s what you’re going to do. DO. not attempt! OK?
Still with me here?
You’re going to loop the bike right over and step off the back. – to do this.
Pre-load he fork and as it reboundsthrow your weight back over the rear wheel while simultaneously pushing the cranks (and rear wheel) forwards with your hips just as you are required to to initiate all manuals.
But…
As you move your weight back over the rear push the rear wheel far further forwards with a far stronger push from your hips than you need to to reach the balance point. As the bike is reaching the balance point remove a foot (which foot i up to you – I can ride Ambi/switch so can do either no bother) and simply step off the back. I know I make this sound simple and you may find the thought of this a little scary but once you’ve done it you’ll realise just how simple it actually is.
I’ve taught tons and tons of people to do this and so long as they are genuinely ready to commit ALL have managed it.
It’s far easier to teach in person than to type.Your (and most STW skills advice threads I read) main problem is worrying/overthinking and getting all anxious instead of *riding your bikes more and making small gains.
*Riding =/= off-road miles. i mean timeon the bike (anywhere, just messing around)
I’ll happily take all the beer on offer BTW. I’m already incredibly stylish at coming off a bike.
roverpigFull Memberso long as they are genuinely ready to commit
That’s the tricky bit though 🙂 I’ve tried this a few times, but once I reach that point where it lifts up properly my brain just freezes and I end up on my arse, which hurts. Then I find it hard to commit again. I know I should be able to just step off. It sounds simple, but I guess that’s just one of the downsides of being a born coward.
funkmasterpFull MemberComing off doesn’t bother me (I do it often enough that it’s practically just part of the ride) it’s more understanding the mechanics of getting to that balance point to begin with. At the moment I’m just using brute force to raise the front end, which I know is wrong.
I’m going to keep practicing and take on board all the help from this thread. Once my head understands the process I should hopefully be able to crack it. Geex, your explanation makes sense to me, so I’m going to roll with that.
Thanks again everyone.
geexFree MemberRealising now some of you can’t actually wheelie. Amend my above advice and practicing stepping off the back from a wheelie before a manual. You should get it quicker. and when you start learning manuals you shouldn’t have that fear.
Brute force is massively wrong mate. Learn to wheelie first. As an example: Getting the front wheel up to balance point if you’re descent at wheelies isn’t difficult using only one finger to hold each grip.
vickypeaFree MemberFunkmasterp, perhaps we should get geex to come to Macc and teach us 😀
geexFree MemberFine by me. Are the Macc Lads still going? and how old is Julie now? 😉
maxtorqueFull MemberOne thing that perhaps should be said is that the continuous flatland manual, whilst looking pretty boss in the average trail centre car park, is really not that useful a skill in the real world!
Far better to learn how to do a decent small american, ie front wheel first, bunny hop IMO. An 8 to 12″ hop you can pull out of your bag-of-tricks at short notice on the trail is useful in lots of situations, from keeping your feet dry across a puddle to effortlessly flying up and over those logs the local trail sabbo has unexpectedly pulled across your fav run!
(it also helps with jumping ultimately, and gives confidence in lifting the front of the bike, to avoid plonking the front wheel into holes, ruts or whatever)
So if you’re struggling with the manual, and can’t bunny hop, i’d suggest trying to learn that one first 😉
geexFree MemberYou honestly thought that was worth saying in a thread where people are asking specifically how to perform and hold manuals?
See my second post in this thread 😉
vickypeaFree Membergeex- apparently the Macc Lads have recently reformed. The Virginmarys are a really good Macclesfield band.
maxtorqueFull MemberYes Geex, i think it’s a more than valid thing to say on a “discussion forum” where, you know, we discuss stuff! 😉
sirromjFull MemberSo if you’re struggling with the manual, and can’t bunny hop, i’d suggest trying to learn that one first
Well true bunny hopping is probably more useful, but if you’re still using your arms to get the front wheel up you’re limited to how high you can bunny hop. I can do 40cm after a couple of attempts, but 45cm, or about 2/3 diameter of my front wheel, seems ridiculously difficult (though fatigue from too many attempts doesn’t help either).
I usually cycle 6 days a week on various MTBs so I have no excuse for not learning to manual, other than not being assed. Perhaps if it will help with bunny hopping then that’s a good motivation as bunny hopping onto things will make my local riding a lot more fun.
geexFree MemberSirromj
Learning how to Manual won’t help you with bunnyhopping. unless you are wanting to hop from a manual or into a manual. Manualling will help with erm… Manualling. (what you do with your manuals, ie’ pumping rollers, squashing lips etc. is another matter)
You can already bunnyhop. You just need to learn how to get higher. And BTW you most certainly do need to use your arms to bunny hop over the height of an mtb wheel. Obviously you still have to use weight shift to initiate raising the front wheel but to get it high enough to clear the height of a 26/27.5 wheel you need raise your front wheel higher which means picking up the bars and pulling your stem towards your chest before pushing them forwards as you lift the rear wheel. Not doing this high enough might be why you’re struggling to get higher.Can we discuss pies now? If you can’t manual a nice pie will definitely make you feel better. and might even be more useful. Especially in the real world. Wherever that is.
howsyourdad1Free Membermanualing and bunnyhopping are heavily linked though. The manual front wheel lift is used in both . you are suspending it off the ground (not lifting it).
A bunny hop is more temporary suspension, a manual is a sustained suspension. so i do think they help each other actually
geexFree MemberThey really don’t.
All fundamental mountainbike skills are linked in one way or another. Riding your bike in a flamboyant manner (hopping/jumping/pumping/manualling/tweaking/styling etc.) keeps your skills sharp. But that’s how I always ride. Doing bunnyhops doesn’t really help my manualling skills at all. but manualling and being able to hop from a manual increases my skill set. (god I hate that term)
Bunnyhopping anything reasonably high (12″ is not high) requires massive pre-loading. Wheras initiating and holding a manual requires much more subtle inputs.
You can learn to bunnyhop and manual at the same time. Of course you can but if someone is asking you to teach them how to manual coming steaming in and suggesting they learn to bunnyhop instead makes no sense. Repetition is key in learning new skills. ie. finding the balance point and learning how to hold it when manualling. Eventually this repetition will become muscle memory. The person who has asked you how to manual is obviously motivated to want to learn manuals. Probably because it does look cool. Use that motivation and let them learn manuals instead of bombarding their brain and body with bunnyhop technique repetition too.
IMO Manualling is one of the most fun things you can do on a bike. Bunnyhops way less so.
Heeey maybe I just like looking cool 😉
howsyourdad1Free Membersorry who is doing the bombarding? you are answering loads of imaginary stuff that i didnt write. all I have said really is practice. it is a discussion forum and the discussion had turned to how the two skills of manualing and bunnyhopping are are linked.
Although for some reason it seems that it often turns back to a certain flamboyant cool guy.
kelronFree MemberPracticed a bit this morning, the suggestion to keep a foot planted on the ground really helped me get a feel for what I should be doing. I think before I was trying to throw my weight back more than push the bike forwards.
I haven’t managed to fall on my arse yet but I’ve managed to get the front wheel higher and with less effort than I ever managed before, so it feels like I’m making some progress.
Thanks for the advice geex and others.
nicknamelessFree MemberI too am trying to learn (only been riding just over a year) and am also in mids 40s – old dog new tricks eh!
I have found the L shape advice to really not be that useful and not at all illustrative of the ‘thrust’ to initiate rotation that seems to bring my front wheel up.
This is actually the best illustration I’ve seen of someone who has this pat, and it’s not even a vid about manualling;
At 2:34ish
kerleyFree MemberMy advice is don’t try them in a garage with a brakeless BMX.
I have luckily been riding fixed gear for years now so that will never happen again – bunny hopping on a fixed gear is a good challenge though although it is almost cheating for wheelies.
richmtbFull MemberI’m liking this thread, has inspired me to go to the big grassy area in my estate and make a tit of myself
sirromjFull MemberYeah. Tonight’s commute home will be all about stepping off the back, though I do need to get home at some point.
The topic ‘Manual madness’ is closed to new replies.
