Think i'll give the open office a go then, as I asked above, anyone had any compatability problems with Power Point between MS and Open office (Mac versions)
Yes. Lots of problems with Power Point vs Presenter (I think that's what the OO thing is called).
Things work fine if you use just Power Point, or just Open Office Presenter, but the moment you start transferring things from one to the other, things break.
It is particularly bad if you use videos, web links etc, but even things like images sometimes go a bit wobbly.
If you need to view presentations from Presenter on someone else's PC, best way is to save as a PDF, although obviously not a goer if you have video / audio.
Open office writer / word compatibility is somewhat better, although if you do anything cunning with formatting, or are particularly tight for space, you need to open things up in Word and check that it has the right number of pages, as sometimes things format very slightly differently. Also if you are using other people's templates (we have to do it for publications) be careful, as sometimes it can change them slightly, meaning it gets rejected by the person you send it to and causes a whole load of hassle.
If she is at college, then office is only £40, and you get the full version too, with all the bits. Although it occurs to me, I don't know if they do a mac version on that deal, probably do…
http://www.microsoft.com/student/discounts/theultimatesteal-uk/default.aspx
Joe
