Viewing 3 posts - 1 through 3 (of 3 total)
  • m985 vs m980 cranks – much strength difference?
  • I’m looking for some cranks on a new build trail/AM bike and can get a deal on some M985’s. Are they likely to be much weaker than the M980’s or equivalent XT/SLX offerings?
    njee20
    No different to 980s whatsoever, only difference is BCD (which is a pain if you ever want to run non-XTR rings).
    No reason to think they’ll be different from XT/SLX, unless you’re looking at older SLX with steel pedal inserts.
    I thought that would be the case. cheers
    I’m going to run a wolf tooth chain ring so should be fine.
The topic ‘m985 vs m980 cranks – much strength difference?’ is closed to new replies.
