Last night while attempting to extract the rear brake from an Orange Five frame I somehow managed to pop a piston out of the caliper, spray all the brake fluid over me and the shed and generally make a mess of it. The piston appeared to pop back in ok and so I moved on to attempt to fit it to the new (to me) frame. Turns out that the new frame needs a longer hose….luckily I had a longer hose on a set of identical brakes (that have dodgy seals) in the spares bin and so I just swapped the hose over (original banjo, mini seals, olive, insert, the lot). I then bled the system twice (as a lot of dirt came out the first time) and tightened everything up.
I can’t see it leaking anywhere under pressure and there is little lever throw. So, have I just been exceedingly lucky and the jobs a good’n or is this all likely to fail when I least need it to and end in a tragic tale?
