Home Forums Chat Forum Like sugru, but non adhesive – suggestions?
Viewing 9 posts - 1 through 9 (of 9 total)
  • Like sugru, but non adhesive – suggestions?
  • scruff9252
    I’ve a project in mind that would require clamping a collar, designed for a straight stainless tube circa 22mm into a  tapered stainless tube – so will need a shim. Non structural & not needing to hold a large force or heavy load.
    Probably a good job for a 3D printer, but I don’t have one and don’t plan to buy one.
    could also bodge with wraps of self amalgamation tape, but prefer something “neater”
    I could use sugru to make the shim, but I do not want to glue the parts together. Ideally it would be like sugru and harden into a monolithic firm rubber shim, but not adhere to the metal. Is there a product on the market that would achieve this?
    thanks.
    johnners
    Spray some lube on the surfaces and the sugru won’t stick when it sets?
    scotroutes
    I was going to suggest wrapping both items in clingfilm before fitting, then removing it once the Sugru has set.
    mattyfez
    Any heat involved that might need to be accounted for?
    Duct tape or aluminum tape?
    jairaj
    Polymorph plastic ?
    It’s starts off as plastic granules that you put in hot water for a bit. It becomes mouldable and then once cool hardens.
    ElShalimo
    Can you use that to fix a dishwasher cutlery tray?
    DT78
    look up “blue stuff” might do what you say, i use it for creating moulds for resin components
    scruff9252
    Thanks all – both the Polymorph plastic and Blue stuff both look ideal for my porpoises!
    Kuco
    I did this to make a shim for a seat post mudguard. I just wrapped cling film around the post and put a small bit around the clamp., worked fine.
