I have the very light you are considering.
It is very good, no question about that.
It is also moderately infuriating at times. It frustrates me massively that I need to tell the two button remote to work in two button mode every time I use the light. This is because you pair the remote as a fresh device every time you connect the battery to the light. You have to do this every time you use the light because if you don’t the battery will drain. It does that anyway, just slower if it is disconnected.
Also, the charging port requires a small, finicky insecure adapter to connect to a USB-C cable. It’s got a USB-C socket but because it is a deep set weather proof socket there is no USB-C cable I have found yet that will connect without this stupid adapter.
Also, they have two cable lengths. One is too short to put the batter anywhere other than on top of the top tube right behind the stem, the other is too long and means cable needs wrapping around all manner of things to stop it snagging.
I think I probably had higher hopes but it feels like they have built a great light, come up with some design issues and just bodged them.
