I’ve never gone as far as buying and trying, but I’ve often thought about replacing the 8-speed 11-30 cassette on the Wazoo with a 13-26, to give smaller sprocket jumps and still a reasonable gear range for road use given the 24/38 chainrings.
But the long cage rd-310 rear mech officially has 28T as the minimum easiest sprocket (and officially supports at least 34T) IIRC and I forgot all about this when I ordered a replacement mech a couple of months ago.
Albeit just like on my road bike, I’ve needed to sort out a replacement rear mech cable for months, so I’ve been typically stuck in 17T… Which makes https://www.strava.com/segments/19814823 a bit of a slog of late on the commute home using a 700x50mm Schwalbe Century up front and 26×4″ JJ on the rear!
