Viewing 38 posts - 41 through 78 (of 78 total)
  • Landscapers / builders help! – Decking this time
  • revs1972
    Member
    I’m not an expert on concrete, but I wouldn’t be using postcrete to make pads.
    It’s ok for what it is designed for , I.e to surround a post in a hole, which ground pressure / stitchion etc come into play, but if exposed then it’s not got a lot of strength and can blow out fairly easily.
    Use the ready mix concrete or high strength concrete instead. It’s a couple more quid a bag, but it’s the old adage, buy shite buy twice 😉
    Premier Icon stumpyjon
    Subscriber
    Wtf are you mortaring with that? 5:1 is the most common mix, maybe 3:1 for pointing in exposed circumstances. 3:2 and you’ll get loads of problem with shrinkage, not to mention it costing triple what it should
    Oops, should have been 5:2 ratio, from my father in law, ex victorian builder who still went to work in a suit jacket and tie. Proper old school. Worked well for me on the walls and garage I built.
    jim25
    Member
    Don’t use postcrete for a supportive structural pad, there’s good reasons why proper concrete mix is used in structural situations.
    Either mix it up with ballast and cement yourself 5:1 or look into if you can pre mixed proper concrete (I’ve no idea if you can, we always mix our own,I’m a builder by the way)
    Personally , a 6” cubed pad isn’t big enough. Your bearing all the weight of the deck and what ever you put on it on a 6” square…. it will most possibly subside over time, make it bigger, at least 300mm square and deep, deeper the better really, especially if there is a slope involved
    1 bag of 25kg premixed concrete would do 1 300x300x300 hole I should think, but always best to budget for more as your holes are never going to be the exact size you want them to be.
    Sounds reasonable! Thing is, 16 bags of pre mixed stuff is going to add at least £150 to the cost.
    I’d hoped I’d be using some breeze blocks for a few quid!
    The 150mm cube idea was based on a B and Q guide but yep it doesn’t sound a lot to put it on, especially with the inflatable hot tub going on it.
    This is rapidly turning into a nightmare ish money pit of nightmares..
    Plenty folk sit them on slabs, and there’s always folk giving slabs away. Mine is sat on a full 6″ concrete pad, I had a load of broken slabs and aggregate to get shot of, easiest way was to use it as a deck base, it’ll never move! (and it never has)
    johndoh
    Member
    I levelled mine at as much as possible by digging over and levelling up the topsoil then used some old paving slabs (from a pre-existing patio area I had dug up) as padstones and built up (as I wanted the decking to be raised up from garden level) using bricks on sand & cement dabs at 18” centres before laying a 4×2 framework over and then laid the decking over.
    I’d thought about the slab idea but then heard a few horror stories and was wondering how to level them?
    Most of the ground is pretty firm, it’s just soft towards the back.
    So my options are;?
    -Dig 16 holes, 4*4 posts , postcrete and bolts
    -dig 16 holes and make 16 300mm pads
    – stick 16 breeze blocks down and er hope for the best
    – use old slabs and figure a way to level them?
    – spend a fortune on a 3.7m square concrete base (I imagine very expensive!)
    I’ve found 46 * 17” slabs locally for £35
    Wondering if something could be done with them, given my lack of budget time and skill 🤔
    johndoh
    Member
    uwe-r
    Member
    So my options are;?
    Why are you not just digging in 16 4×4 posts and postcreting them in. There is a lot of labour in digging but if you have the time that is not an issue (not sure what the ground is like – mine was awful digging through rubble by hand). If you have vertical posts then getting it level is a piece of piss. Getting it square is the challenge.
    Looks good Jon – this would certainly be cheaper!
    Might sound a stupid question but say I get the slabs I mentioned and use two layers or blocks on top –
    if I add mortar / cement to first slab, a
    add second slab/block and tap down until level – is the mortar going to be strong enough not to compress when I add the deck?
    Mostly because I don’t have a lot of time and the ground in some places is almost entirely hardcore (yet annoyingly soft at the back of the plot)
    Premier Icon Greybeard
    Subscriber
    What we did for my son’s deck was to make short posts out of 6×2 and whack them in with a rubber maul (a BIG rubber mallet) until they wouldn’t go any further. From memory, on about a 0.4m x 0.5m grid. Then marked them off and sawed them level using a circular saw. The 6″ dimension was across the joists so that we had some positioning tolerance if the post didn’t go in quite square. That was 3 years ago and they haven’t budged.
    uwe-r
    Member
    po
    uwe-r
    Member
    I think you will still have to mess about in the dirt whatever solution. I’d just get out there and start digging.
    PS. I started mine last August and it still is not totally finished. I took 2 weeks of work last summer I spent about 4 days digging and messing about with the posts. Another week on the frame the rest of that time lost just staring at it (and or watching youtube videos). Then got the deck down on weekends over autumn and this spring and did the hand rails about 2 weeks ago. I just need to face it with bricks now.
    You could set 4 posts in postcrete, one at each corner, at the height and level required.
    Build frame from this, then slab under as many junctions of purlin and joist as you wish, with a slab dropped below, and wooden leg cut to length, then there’s no eed to level all of them, just the 4 on the outside.
    Similar really to what Jon has done, but you’ll need a lot more joists, I always do 400 centres, especially with the weight you’ll be putting on there.
    johndoh
    Member
    There were more joists by the time I had finished – it was WIP when I took that picture 😉
    I thought that, was just to make sure he knew! 🙂
    😃 yep, I’ve ordered timber for 400mm centres
    Next idiot question ..
    Assuming I did as John did, given the length (3.7m) could I just level (with a level and long timber) the corners with slabs and bricks/mortar or would it be better to level each support individually to each other in turn?
    I can see this being me almost exactly! I’m supposed to be studying full time rather than playing with wood in the garden 😐
    uwe-r
    Member
    Mine was built of the back of the house over an old outbuilding which had serious foundations which made it extra complex. it was also built about 4ft up and part of it over the old cellar access steps so over 2m drop in one bit. I fell through it twice during construction luckily not in the worst bit and no serious injury. Don’t rush it just keep plodding along getting everything nice and square/level. Make sure you have a good saw set up as you will be doing a lot of cutting.
    Top tip. If you find some of these they fit a 4×4 post in the centre square perfectly. Dig one of these in to each hole and use them to help line up the square. Support the post level and then postcrete. Once you have the 4 corners in everything else is fine.
    loe
    johndoh
    Member
    If I am understanding you correctly, I levelled them approximately before laying the joists over and levelled in all directions – front to back, side to side and diagonally – and padded it out where necessary with extra shims. I was trying to do it as cheaply as possible so I asked at my local builder’s merchants if they had any odds and sods of old paving sets etc that I could buy and they just directed me to a corner of the yard where I could fill up the car with whatever I wanted for free – just old bits n bobs that they could never use.
    BTW, my effort is 3 years old now and it hasn’t moved or shifted at all.
    rydster
    Member
    I’d be cautious about putting in substantial pad foundations. What you put in now you may want to take out in a few years. This isn’t an extension, more like a garden shed in terms of mass and loads. Many Victorian houses are still standing with brick footings only and like a wooden deck can handle a little movement. Hammering it your posts until refusal would prob be enough.
    I’ve just had my framing timber delivered.
    Do you reckon this is ok with a split in the end, it’s going to be screwed into after all?🤔
    https://ibb.co/LPVNfJJ
    What did you use for shims john?
    I was wondering if I should level from each post to the next with a spirit level and adjust the mortar between slab and brick accordingly or try to level from the far corners from each other using the spirit level on a straight edge for example ?
    Aye, just shove a screw down from the top. Be fine.
    So, the saga continues ..
    I’ve now sourced 20 odd 40mm paving slabs that (it turns out) are the ridiculous 30kg ones that are horrible to lift..
    I’ve also got some smaller bricks and off cuts I can hopefully use for levelling.
    So… will pre mixed mortar be strong enough to dab between the slabs and bricks as per John’s decking above?
    Is it better to level each support to each other with a 1.2m spirit level, or put the level on a joist and try to level across the full width of the frame?
    Thanks 😊
    *40kg slabs 😳
    So, for anyone bored enough to feign an interest, I need some advice.
    Having nearly destroyed my car by transporting what turned out to be 800kg of slabs in one go (yes, I know) I’ve now got my plot covered in weed membrane and the fence half heartedly re-preservative-ised.
    However, because the slabs are big (600mm square) I’ve now got an issue trying to stop them rocking.
    Is there any recommended way of stabilising them on membrane, or should I try to smash them into smaller bits?)
    Thanks again
    You need the 600m square area below each slab flat, that’s all.
    glitch
    Member
    To stop them rocking, standard procedure would be to make up some cement. use a pile for each corner and another in the middle (covering what it will be supporting, and put the slab on top. – then tap it above the piles to level up using your spirit level.
    If the ground is flat enough that a smaller piece will be stable then you could always try to use a smaller piece, but if it isn’t flat then you will have a smaller contact with the wood sitting on top of it, and if you get any rot the deck will start to flex sooner. – However if you will already be putting a secondary masonry element above (brick etc) then of course the mortar layer between those can be used to give a level surface for your wood to sit on.
    Thanks, can I put mortar onto weed membrane? I don’t really want to attempt to cut 20 * 600mm holes in it!
    Yep, for info my plan was the huge slabs and then a breeze block on top (mortar between the two to get levels), then frame on top of that
    glitch
    Member
    I don’t think mortar would react in any way to the membrane, so that’s fine. It may bind as some mortar may seep into the weeve, but that shouldn’t be an issue for you.
    As long as the slab is in contact with the ground at the point the block will sit above, for weight transfer straight to earth it wont matter if part of the slab is floating as such. as long as it is stable in that position. If it is wobbly, and not in contact with the ground at the point of support, it is much more likely to crack and cease to be a functional support.
    I guess the big question is how wobbly are the slabs when in the correct position. Even a bed of builders sand would help to stabilize, but at that point you may as well mix some cement in as then there is no way it will shift in the long term, could go for a weak mix just to hold it solid.
    johndoh
    Member
    As per my picture, we didn’t have an issue with rocking as the ground was flat and the product I used was also somewhat more robust than normal weed membrane – it’s commercial-grade non-woven geotextile used under railway lines and roads etc so it really helped stabilise things. However I wouldn’t expect individual slabs to rock when you have fixed everything together no matter what membrane you have used (and I didn’t use dabs UNDER the slabs). BTW, I shimmed with all sorts of bits n bobs such as old bits of slate and tiles (my father in law, not only being a source of above-mentioned geotextile, is a habitual hoarder of stuff like that ‘just in case’ – in fact you can see some at the bottom of the first picture).
    And I feel your pain re. the paving – I just used the last few I had to extend a walkway don the side of my house and I had forgotten just how heavy the bloody things are!
    Another question – is it a bad idea to build the frame on a slope and then move it into position?
    I can either build it on the lawn (on more of a slope) and try to move it onto the supports, or attempt to build it in situ but not aligned to the supports (ie build it and then lift and shift slightly)
    Ta
    I did the slabs method when I built mine in front of the patio doors and it was fine – lasted years.
    However, the landscape gardener who built the current one did the above method 🙄 and LOTS of them, mainly due to me having two buildings on the decking.
    Both have been a haven for rats though
    Subscriber
    I can confirm concrete under slabs onto a weed membrane works well. I bodged a load of 300mm slabs with a 50 mm gap between them 15 years ago, expected it all to break up and move within a year, still solid and not moved today.
    Build the frame on the slabs, it’ll be really heavy to move.
    There’s no way you’re lifting a 3.7 x 3.7 frame.
