Hi all
Thanks for the advice. Once I knuckled down and wrote down all the stuff I know I’ll need I realised that I don’t need that big of a selection, so the universal press kit was a bit overkill and also wouldn’t cater for hub bearings over an axle from what I could work out. I already have a Yeti specific one for my old classic full susser so thats a lot of the random sizes covered.
A bearingprotools.com bearing press with drifts for 2437 and 6805 bearings was £22. I added on a headset press with T-Bar handles (handles can also be swapped to the bearing press) for an extra £26.
Then I realised the Hope service kits are cheaper when bundled together, so to get all the tools for Pro 2 and Pro 4 hubs including the freehub seal tool was £30 and I can use these with the bearing press above.
I finished off with the 9 piece universal slide hammer removal set as it works on properly blind bearings whereas the bearingprotools ones, although they look better quality, need to be bashed from the blind side which sometimes isn’t possible, and when it is, always has the potential to hit the bike!
