I have a new doorway and I’d like to use a ‘spare’ door I have as it matches all the others – only issue is that it’s about 10mm too short.
The door is made of solid dark hardwood (def not hollow/cardboard/eggbox) that has been painted.
Can I simply screw/glue a 10mm piece of timber to the bottom (or top) of the door and fill/sand it then paint the whole thing?
One complicating factor is that the floor has a slight slope to it so I presume this means I’d need to add the extra height to the top rather than the bottom allowing the bottom to be trimmed to match the floor.
Does this sound OK or am I barking up the wrong tree?
