- This topic has 130 replies, 36 voices, and was last updated 1 year ago by piemonster.
Jigsaw and Router for basic cabinets
footflapsFull Member
Does anyone know any good books or Youtube channels for someone who has never built any furniture before? I want to attempt a wall to wall TV cabinet and then maybe some wardrobes under a wonky attic ceiling.
Start with Peter Millards series on building a basic cabinet…
piemonsterFull MemberAre adapters fairly commonplace to allow a router to run on another manufacturers rail guide, from a Festool track saw in this case?
piemonsterFull MemberI’ve also gained access to a decent jigsaw, so I can scrub that.
footflapsFull MemberAre adapters fairly commonplace to allow a router to run on another manufacturers rail guide, from a Festool track saw in this case?
Hunt on ebay etc e.g. https://www.ebay.co.uk/itm/283982445727
Also, have a look at Benchdogs etc, they do lots of adpators / bench things for cabinetry (mainly aimed at those with an MFT).
Rail squares are a good addition to a track: https://benchdogs.co.uk/collections/rail-square
maccruiskeenFull MemberMy quarter inch Elu router which is at least 35 years old and has suffered endless abuse on site is still going strong, in fact I’ll be using tomorrow to hang doors.
I recently borrowed someone’s quarter inch Trend router which I thought was the pretty much the identical design,
Quite a few brand routers are related around the the old ELU routers – Dewalt, obvs because they bought the company but I think the guts of Trend routers are the same as the old ELU too – they’re all actually all different badged machines (along with ones badged as Metabo, Freud and Fein) made by a company called Felisatti***
In some respects they’re all pretty tried and tested and in essence a router is pretty simple tool, just one that needs to be well made. But they’re very old designs now a lot of stuff that should be built-in (like properly functional dust extraction) is a bit bolt-on after-thought.
The reason I gave up on my Trend T7 was it was such a time consuming fiddly faff to just change a cutter if you had the dust port attached (and the the port was so flimsy)
*** Russian owned incidentally so time will tell if thats of any consequence
maccruiskeenFull MemberAre adapters fairly commonplace to allow a router to run on another manufacturers rail guide, from a Festool track saw in this case?
There’s a guy making little 3D printed rail adaptors on eBay – I’ve got one for running a laminate trimmer along a mafell rail
https://www.ebay.co.uk/str/wegsisolutions?_trksid=p2047675.m3561.l2563
piemonsterFull MemberCouple of questions, I seem to find myself drawn to palm routers, assuming its decent any reason not to when the initial purpose is cutting Dados/Rabbets.
I’m also torn between two ends of the price bracket.
A Katsu
Or a Bosch GKF125
But I’ve no way personally of knowing whether one is better than the other. Anyone had hands on with these two machines?
MrPottatoHeadFull MemberI’ve nothing useful to add here but Routers for some reason scare the crap out of me. I actually stuff cardboard down my trousers to provide some extra protection as I have irrational visions of the bit breaking and spearing my manhood.
kayak23Full Memberany reason not to when the initial purpose is cutting Dados/Rabbets
Housings/Rebates 😉
A Katsu
Or a Bosch GKF125
Palm routers are brilliant. Certainly a good gateway to routing.
Just don’t try to do anything too meaty with them.I’ve not got direct user experience with the Bosch, though we used to get a Bosch demo guy in my last work once a year and I was always really impressed with quality and features.
I have a little 12v Bosch driver which is mint.I do have the katsu though and there is no getting around that it’s brilliant for the money.
I think the fact that you can use Makita accessories with it and katsu with Makita, I would personally go katsu.You can always upgrade once you get a feel for what you’re wanting to do the most.
Cheap enough that you can knock yourself up a little mini router table with an additional one which would make many jobs easier and safer.
peaslakerFree Memberwhen the initial purpose is cutting Dados/Rabbets.
Dado construction is one of those things that Mericans go on and on about, ‘cos they’ve got table saws. FWIW (not much), rabbets/rabbits is ‘Merican too. Rebates is Brit.
I did a full custom kitchen with dado construction with a track saw. I wouldn’t use a router, even on a track adapter. I certainly would not use a palm router.
Piece of pi55 with a track saw. Just make yourself a shim the thickness of the blade’s kerf. Clamp up a straight edge. Cut #1: put the shim against the straight edge, put the track against the shim. Cut #2: take away the shim; put on offcut of the material that will be mating into the dado against the straight edge; put the track against the offcut. You now have the accurate edges of your dado. Hog out the material in the middle any way you care. Track saw is still dead easy for this.
Peter Millard is a goldmine. All killer / no filler.
Arf. You’ve seen the prices of Festool track.
Millard did a video on cross-compatibility of different manufacturers track with different saws, but mostly for cheap saw cross-compatibility. Festool/Makita/Triton are all 98% the same but Makita adds an anti-tipping lip on the back channel and Triton copy that. I’ve used Triton and Festool saws on Makita track. Hint: Never use more than one saw on a piece of track – no guarantee that the second saw won’t trim back the splinter guard and make it useless for the first saw.
Another hint with the festool saw. Blades matter. The default blade is usually a detail 48T blade for cutting laminate without chipping. The saw will struggle if you start running it through thick timber, particularly for rips. It will stall and burn the work. Get lower tooth count blades appropriately if you need them. Also occasionally clean your blades. Meths or isopropyl alcohol work a treat.
piemonsterFull MemberPiece of pi55 with a track saw. Just make yourself a shim the thickness of the blade’s kerf. Clamp up a straight edge. Cut #1: put the shim against the straight edge, put the track against the shim. Cut #2: take away the shim; put on offcut of the material that will be mating into the dado against the straight edge; put the track against the offcut. You now have the accurate edges of your dado. Hog out the material in the middle any way you care. Track saw is still dead easy for this.
Dont suppose theres a YouTube video for that, just so I can verify my understanding of the process is correct.
Theres an attachment for the saw specifically for cutting grooves to width, oh how I laughed when I spotted the price…
jefflFull Member@finbar I have a tracksaw and live in Chesterfield if you want to borrow it, or bring the wood over. Am away this weekend though.
peaslakerFree MemberDont suppose theres a YouTube video for that
On a table saw, but it is the same idea as with a track saw/clamped straight edge combo…
https://youtube.com/clip/UgkxUEJO55nl8jT-pVPLQuGUTlvDwidHGaQ2
footflapsFull MemberI’ve got the Bosch palm router kit: https://www.boschtools.com/us/en/boschtools-ocs/palm-routers-gkf125cepk-119901-p/
Very handy, I mainly use it with a half round bit for edging stuff. It has good dust extraction with the various base plates.
Has very little oomph though, so wouldn’t want to try cutting deep rebates. Also, you need 1/4 inch bits for it, whereas a proper router uses 1/2″.
breninbeenerFull MemberSorry for slight hijack, but did we settle on the STW approved tracksaw? Im a hobbyist, but retired an i could make use of one.
Any suggestiins for the sweet apot of performance and accuracy vs price?
I have dewalk xr 18v battery kit if thats significant, but happy to spend some money to get something that will last me and make a good job.
Ian
footflapsFull MemberSorry for slight hijack, but did we settle on the STW approved tracksaw?
As an absolute minimum Festool, but preferably Mafell.
ernielynchFull Memberbut happy to spend some money to get something that will last me and make a good job.
IMO the only reason not to get a Festool plunge/track saw is the cost, which is a fair reason, they’re not cheap.
But if money isn’t an issue the answer has to be Festool. After years of using one it still impresses me!
footflapsFull MemberPlus the range of adpators from 3rd parties for Festool is massive as it’s the most popular ‘serious’ tool out there.
I went down the Mafell / Bosch route (same track design) and the choice isn’t as good.
kayak23Full MemberI have dewalk xr 18v battery kit if thats significant
A colleague has the cordless Dewalt. Nowt wrong with it apart from the garish colour.
I’ve got Makita. Very happy with it.
Peter Millard is again, a good source for comparisons.peaslakerFree MemberSorry for slight hijack, but did we settle on the STW approved tracksaw
I went from Triton to Festool and it is night and day. With the cheaper options you have to strive to achieve accuracy which comes built in with the better tools.
The Festool (mine is battery powered) has less power than the Triton but using an appropriate blade for the work in hand makes it a non-issue. The latest versions with the thinner kerf (1.8 vs 2.2 mm) blades have a much easier time of it.
Makita is the commonly referenced mid-range option and there won’t be much wrong with it but last time I looked it lacked safety features for preventing kickback.
Last little thing is about battery power vs cable. Using the battery powered festool with the dust catching bag means … no cables or hoses attached and really easy to manoeuvre and a completely portable option with great dust collection. Obviously a real dust extractor is better but I’ve taken my track saw to a timber merchants to break down sheet goods in the car park so they fit in the car. Obviously there are some merchants who’ll do that for you with panel saws but when there’s a bit of a rush on it is useful.
inthebordersFree MemberAnyone had hands on with these two machines?
No, but I’ve one of these and can recommend it:
Sorry, utter rubbish.
dyna-tiFull MemberOr a Bosch GKF125
Or as ‘in the borders’ says, the RTO700, which i also have.
The plunge base on the RTO has a bigger footprint than on the GKF so is more stable, and the RTO also have other bases so overall it is more versatile.
You’ll probably find it best if (whichever) lives mostly on the plunge base, as I’ve found that the small baseplate on the trimmer base, coupled with the weight being high up gives it a tendency to want to tip on edges were only half of that small trimmer base is sitting on the workpiece.
The RTO has an offset base and you can use the triangular baseplate off that to give the router when trimming considerably more stability.
Thats fair comment, they are actually a pretty dangerous powertool. They are top heavy, usually with the handles mounted in the middle so can have a tendency to want to flip over when holding them above the workpiece while running.
This is the offset base fitted to mine. You can see that it allows more of a footprint to sit on the timber so lessens the chance of it tipping over
peaslakerFree MemberRe. routers, I’ve got two very different options.
The beast is the Triton TRA-001. This is 2400W 1/2 inch and lives in the router table most of the time. It is a simple option for the router table because it has the riser mechanism built in. It can swing some seriously large bits and nothing fazes it. It was justified when I needed to template trim some 38mm oak worktops.
The other is a Katsu 1/4in. It is crude but is permanently fitted with a round over bit. Noisy and makes sawdust.
Once again, Millard is on hand to explain the n+1 theory of routers: https://youtu.be/Y_gLxlCcY5Y
I cannot emphasise enough how much I’ve learned from Peter Millard and a few other youtubers.
The genius is in knocking up little jigs that enhance these tools. The fancypants Festool-esque solutions offer pricetags for fantastically engineered functionality but with a bit of ingenuity you can get 95% of the capability for pennies and a bit of time spent.footflapsFull MemberI cannot emphasise enough how much I’ve learned from Peter Millard and a few other youtubers.
What I like most about his stuff is the vidoes are short and to the point. Plus he obviously knows his stuff and all his tips are genuinely useful. One of the few YTers I sponser via Patreon.
BigJohnFull MemberI’ve been reading this thread and planning to chip in but others have mentioned what I was going to say before I got there.
However, as a maker of fine and expensive furniture I’d like to point out that there is no real need for expensive tools. Yes, they improve efficiency and are nicer to work with but they don’t always improve quality.
Before I got my Festool tracksaw I used a really cheap B&Q circular saw for straight cuts. Using a fence (look it up) from a couple of pieces of chipboard it worked a treat. And I used a corded Black & Decker drill for ages too. I’ve re-visited some of those pieces recently and they’re still pretty good.haloricFree MemberI’ve been lurking here for a while, I’ve got a job to do on a door (pictures in the other thread if I don’t trash it), and have been researching table routers, and now after this thread I’ve got all the bits on order to make my own.
It’s a meta job that needs doing before the real job.
kayak23Full MemberHowever, as a maker of fine and expensive furniture I’d like to point out that there is no real need for expensive tools.
You’ll be saying there’s no need to spend 4k on a push bike next! 🙄😉
BigJohnFull MemberYou’ll be saying there’s no need to spend 4k on a push bike next!
Yes but they improve speed and are nicer to have.
piemonsterFull MemberHowever, as a maker of fine and expensive furniture I’d like to point out that there is no real need for expensive tools. Yes, they improve efficiency and are nicer to work with but they don’t always improve quality.
Burn the heretic
redmexFree MemberI had 4 doors to trim length wise, I could have got one of the fellow tradesman to get his festool 55 and hoover set up as a wee favour but I like buying tools and got an Evolution bundle for £180
Saw, 2×1400 tracks and 3 mini tracks that are just bigger than scalextric straights
I did the job easy, did the rail trim first and made sure I had a sheet of usb underneath blade set to 2mm deeper than the thickness of the door
I will probably just sell it all now might get nearly my £180 back as they sent me the wrong saw, it was the updated with the light/laser and all the bags to keep everything tidy when storing in the garagepiemonsterFull MemberCheers all, I’m taking punt on the Makita linked to above (but not the 110v version.
pk13Full MemberDrop me a PM and I will send some cutters I no longer use in the post.
They won’t be new or top draw but more than good enough to play with.
1/4 inchpiemonsterFull MemberTalk to me about bits
Is it a case of buying cheap, seeing what bits I do actually use before investing?
I only really need a couple to start with.
pk13Full MemberTrend. Unless you go fancy twist flutes
As above I can send you some to play with won’t be new thouernielynchFull MemberYeah Trend is the obvious name for router bits. If you are new to routering take your time to learn how a router behaves – it can do a lot of damage to a piece of wood! Really important to remember to tighten up fences/depth gauges properly after making adjustments. And not take off too much material in one go.
Make certain that you are confident of what you plan to do on a piece of scrap wood before attempting it on something that matters.
Apologies if I am assuming incorrectly that you don’t have much experience.
chickenmanFull MemberWealden Tools are good for router cutters, good quality and cheaper than trend.I’m still running an Elu 1/2″ router that I’ve had for 30 years, it’s been great but dust extraction is a ball ache.
kayak23Full MemberSecond Wealden tools. I get most of my cutters from there.
Rutlands are good for selection sets.
I used to buy them for the furniture making course I worked on and the quality was really nice.piemonsterFull MemberCheers all, I’ll take a look at Trend and Wealden
@pk13 thank you for the offer, very kind of you. I’m expect this to be done in grabs hours here and there so don’t mind taking a punt on buying tools so will go that route.Ernie
You’re assuming correctly, total noob here. I’m approaching this on the basis that I’m learning how to use the tool safely first, the figuring out how to do the task I want. Then, if I’m lucky, how to do those tasks well. I’m quite a long way off wanting a well finished product.
