Home Forums Bike Forum Internal dropper post cable rattling
Viewing 5 posts - 1 through 5 (of 5 total)
  • Internal dropper post cable rattling
  • andykellybfc
    Anybody any tips on how to stop internal cables rattling my dropper post cable is constantly rattling anybody any tips that have worked? Read online that fading a pvc tube over the cable works anybody had any success with this method?
    ta11pau1
    This is what I’d use, I’m getting a little rattling from my rear brake house in the internal routing tubes, may get around to putting the cables in this.
    Onzadog
    Yep, as about. Air con pipe insulation. Closed cell foam so it doesn’t soak up water.
    docgeoffyjones
    If you can cover postage I am happy to send you a length of the jag wire tubing I have lots left over from doing my bike.
    Onzadog
    The other option is make a spider out of zip ties to go around the cable. This will stop the housing contacting the inner wall of the frame.
The topic ‘Internal dropper post cable rattling’ is closed to new replies.
