- This topic has 47 replies, 29 voices, and was last updated 3 years ago by edhornby.
Intelligence and memory
HounsFull Member
Just procrastinating whilst I’m meant to be finishing off a uni assignment…. How does a persons intelligence rely upon them having a good memory?
Obviously I’m going to use myself as an example, I’m currently studying for a Masters with the OU, due to mental health issues my memory is shocking, and has been for about 15 years. I’m intelligent enough to know I’m not the sharpest tool in the box, but, apart from chemistry, I understand and follow all the stuff I’m working through and score at 85% and above for all my assignments.
However, ask me what I read through last week and I can hardly remember a thing! I just don’t retain the info. Fortunately for me, an exam last year was cancelled, there was no way I would’ve passed it, no matter how much I revised.
So over to you brainy folk, do you have a good memory and can you recall everything you learnt at uni? Or doesn’t memory matter that much, as long as you ‘get it’ whatever ‘it’ is?
HounsFull Memberheh ok, could’ve worded It better, forgive me I’ve been staring at my laptop most of the day, told you I wasn’t the sharpest tool :0)
But I ‘spose I’m aiming my queries to those who have reached high levels of academia
footflapsFull Memberdue to mental health issues my memory is shocking,
Yep, high stress levels block short term memory. I have bugger all memory of when I was ill as nothing got implanted properly. On the plus side, less bad memories, on the down side a bit disturbing I don’t remember anything, a year of my life has gone missing…..
An ex-employer was trying to get me to help with a patent I’d filed at the time. I have zero memory of it – nothing at all. Only when they sent me all the papers with my name on it did I believe them, zero memory of it. Even after reading the papers, I still can’t remember anything about it.
HounsFull MemberJeez, I’m not quite that bad, but feel for you :0(
One of my main reasons for doing this degree was to try and get the brain working again in the hope it’d help my memory etc
goldfish24Full MemberI have appalling memory. Always have. I was put on special measure in junior school because I couldn’t remember my times tables. I still can’t.
But I also have a phd in engineering and a successful career doing it. I can do calculus, I’m excellent at maths in general, still don’t use times tables
I’m just good at estimating (I don’t rely on a calculator).
I understand things by having a working model of it in my head, I don’t remember how it works based on the rules in the textbook. It’s just my learning style.WorldClassAccidentFree MemberI try to remember the principles rather than the details and then rely on being able to work out the details by applying the principles to the problem.
The metric system of weight and measures is quite rational and interrelated for example. 10cm x 10cm of liquid is 1 litre and (for water) weighs 1kg. When I was working out hot much a hot tub would weigh filled with water so I could plan the foundations and floor needed I saw the tub held 1,200 litres of water so would weigh 1.2 tonnes plus the tub itself.
Water flows down a pressure gradient. Normally that means if flows down hill but if trapped in an aquifer under pressure it can flow uphill. When I look an a geological map I can make an educated guess where the water will be.
Make sense?
goldfish24Full MemberReplying to my own post because I didn’t wrap it up properly: my point is that I don’t think memory is important to attainment. At least it wasn’t to me, and it might not be to you. We perhaps have similar learning styles. A learning style that I particularly value in people I work with – if they “know how it works” rather than “remember the rules” as it were.
HounsFull MemberHence the username then!
I think I’m just worried/self conscious that when I’m asked something about what I’m learning, and I can’t remember (even though I understood it at the time) that people will see that as me being thick instead of just not being able to recall it
footflapsFull MemberSo over to you brainy folk, do you have a good memory and can you recall everything you learnt at uni? Or doesn’t memory matter that much, as long as you ‘get it’ whatever ‘it’ is?
So, back on topic.
A few years into my first job I started to think I was losing all my maths knowledge as I wasn’t using it. So I started an OU Maths degree in my spare time, just because.
I spent the first year (2nd year of degree) just re-learning stuff I’d already done as Engineering (my 1st degree) had a lot of maths in it. Then the next level (3rd year) was all new stuff. I then went on to their Maths MSc course, but then bought a house and stopped it as DIY was eating up all my spare time.
Can’t remember any of it now, even though I’ve done most of it twice! I reckon I could still pass an A level today without much sweat, but anything beyond that is all a very distant memory.
goldfish24Full MemberWCA put it nicely. I almost always work out what’s going in with a problem from first principles. Some idiots come along with an equation for the weight of a hot tub that they recall from college, but WCA actually understands what’s going on.
NobeerinthefridgeFree MemberDitto.
Last year at uni the maths stuff was tough going (45 years old and didn’t do beyond standard grade) integration, laplace transforms, fourier etc, all that stuff, passed exams on it all with north of 70%.
I wouldn’t know where to start with most of it now. 🙈
Does it possibly depends on whether it’s something you enjoy or think is important?. My wife isn’t hugely more intelligent than me, degree educated nurse, but has a phenomenal memory. She knows every patients history that comes into her unit, some of them are only admitted every 4-6 months, incredible.
But she asks me on a daily basis how to work the fire stick remote control. 😁
HounsFull MemberYeah I understand that WCA and its a good example as aquifers etc is something I’m learning about this year
as long as I can picture something in my head I get it. Hence why I struggle with chemistry, I just can’t picture it in my head (I need to go back over cation exchanges in soil for my assignment 😖 )
IHNFull Membermy point is that I don’t think memory is important to attainment.
I’d disagree.
Memory is knowing stuff without really having to think about or look it up.
Intelligence is working out stuff from other stuff.
The really clever people have a lot of both; they have a massive bank of stuff they just know, and they’re incredibly good at working out new stuff from it. They then remember that stuff, work out more new stuff, and so it goes on
WorldClassAccidentFree MemberThanks! The way I think about electrical measurements seams to please some people and puzzle others. Think of electricity like a river.
Volts = How fast the water is flowing
Amps = How much water is flowing past
Power = How hard it is to walk across the riverHounsFull Member(off at a tangent now WCA, but I really enjoyed the work I’ve been doing around Darcy’s law)
WorldClassAccidentFree MemberI agree with IHN – you need a balance of memory and intelligence. If you have to go back to re-read everything before you can use your intelligence to process it then you will not be very successful. Equally, if you can remember everything you were ever told but don’t have the intelligence to use that information then the same thing happens.
The trick I find is to remember enough of the general points and know where to get the detail if required and have enough intelligence to know when you need the accurate detail.
WorldClassAccidentFree MemberDarcy’s law – You have to take your shirt off and stride around purposefully twice an episode?
or this one which is what I used without knowing its name
Darcy’s law at constant elevation is a simple proportional relationship between the instantaneous discharge rate through a porous medium, the viscosity of the fluid, and the pressure drop over a given distance.
thepuristFull MemberFor me ‘getting it’ is more important. I still remember when I was studying for my maths finals and had an epiphany where I finally *understood* Sturm-Liouville systems. At that point I could close the book and do something else. Didn’t come up in the exam though so that was waste 🙁 These days I couldn’t tell you what one looked like, other than that they have eigenfunctions as solutions (whatever that means!). So I’ve forgotten pretty much everything I learned at uni but that time has taught me an approach to problem solving and understanding that has stuck with me.
maccruiskeenFull MemberI suppose it varies by disciple but the point of many fields of study (and work) isn’t to be taught and retain information – it’s to learn how to think, reason even to learn how to learn.
it wasn’t the point of my eduction to be taught anything that I’d need to recall later. In my line or work I’m having to learn new stuff all the time knowing that in all likelihood, beyond achieving the goal in hand, I’ll never need to draw on that information again.
HounsFull MemberYour answers are somewhat of a relief, that negative self doubt creeps in so it’s good to hear others thoughts
Sadly it’s the second one WCA 😂
KlunkFree MemberI’ve found my memory has changed since the advent internet/computers. I tend to remember where to find the information rather than information it’s self. So I tend not try and remember details anymore and i think my brain subconsciously willfully disregards it’s knowing that theres a box in the corner that retrieve it verbatim.
footflapsFull Memberother than that they have eigenfunctions as solutions (whatever that means!).
Yes, we used to use Eigen vectors for something in beam forming antenna arrays. Can’t recall what exactly, but I occaisonally drop it into conversations about them just to sound like I know what I’m talking about.
If you don’t have that then you’re probably a sociopath…
HounsFull MemberAs long as we have electricity, an internet connection and know how to type something into Goole we’ll be reet
bradsFree MemberI have worked in energy production forever, and the most successful people I have known have all had great memory. Not massive IQ’s or suchlike but an ability to recall facts is what has got them on in the job.
Mines is crap.
smudgeyFree MemberOP if your memory is that bad with depression then you need to get treatment for it. My memory especially short term was absolutely destroyed with a bad bout of depression and it took ages to get it back. Even now its not that great.
Intelligence I think is very subjective anyway, what’s intelligent to one person in a certain setting isn’t to another.johnx2Free MemberI understand things by having a working model of it in my head, I don’t remember how it works based on the rules in the textbook.
Likewise. I’d say I have a poor memory for names, dates, and for things generally I don’t understand. But the moment you can fit something into a framework, understand it, properly get a handle on it, then it’s unlikely to be forgotten.
To me this implies you weren’t that interested in what you were reading, or didn’t have a way of connecting it to other things that you know? I guess that’s inevitable to an extent with a new area, though I’d also take it as a sign that stuff that you’re actually interested in you’re likely to be better at doing.
Fwiw most memory strategies for remembering random stuff work by increasing depth of processing, often by tying things into some kind of framework (like ‘memory palace’ or which relies us all having a pretty good memory for location). These types of strategies do work and potentially are useful if you can be arsed to use them (not that I do, or very rarely), but I don’t think they’ve got much to do with intelligence defined by me as understanding to operationalise in some way knowledge. Anyway – find a way to be interested (chemistry I’d find a challenge).
(qualifications: great memory for narrative, good at pub quizzes, wear glasses so people think I’m brighter than I am…)
goldfish24Full MemberI think I’m just worried/self conscious that when I’m asked something about what I’m learning, and I can’t remember (even though I understood it at the time) that people will see that as me being thick instead of just not being able to recall it
So I actually suffer this. I mentioned earlier I work in engineering, at a high level. So I regularly get asked difficult technical questions by my boss. Several years ago I went on a management course about learning styles. It taught me we’re not all the same in terms of how we retain and deal with information, and how we present it. Following that I asked my boss to try and direct difficult questions to me via email, rather than corner me in person. Because In person I’d bluster and cover my arse, but via email I’d have time to think and give him the answer I really meant. Over the years we know each other well enough to talk on such matters in person again but that approach worked when we didn’t know each other well.
shootermanFull MemberMemory shot to pieces here too but trying to get that resolved.
I sometimes think you retain information better if you actually understand the subject matter on a macro level rather than just trying to remember string of facts. I realised later in life that the study style I was taught in school was just cramming in facts to pass exams.
The other thing is, I think, that as you get older you’ve got more responsibilities and just stuff constantly bubbling away in your brain that you simply don’t have the blank canvas you has when you were younger.
TiRedFull MemberIntelligence is the speed with which you acquire new knowledge (information is not knowledge as one also needs understanding). It has little to do with memory. Although if you are learning new things in the context of existing knowledge, that helps with the memory side by keeping it fresh. Otherwise it just falls away.
Keeping key information in a single place is helpful as one only needs to remember where that place is rather than the content.
DaffyFull Member@IHN has it about right. The smartest people I’ve met and worked with have encyclopaedic knowledge of things they’ve read, the author’s who wrote them, the connected theories on why a particular approach was better, etc. They are able to draw on that knowledge along with their own intelligence and apply it instantly to a particular problem.
When looking at a presentation at a conference, they are easily, inside 30s able to spot problems in complex connected equations, not because they’ve worked them out in the 20s it’s on screen, but because they’ve seen it before, seen it correctly applied and KNOW it’s wrong.
This is a significant advantage in almost any setting, but particularly in dynamic environments with multiple people contributing to a discussion.
igmFull MemberWCA – as a power engineer for many years, no, just no.
Power = How hard it is to walk across the riverYou can have the Amps and power ones (though I don’t really like your power one – it’s ok), but not the volts.
Voltage exists even when there is no current flow. The water in your analogy is still.
A better description of voltage is potential difference – one that we used to use all the time. Voltage was the unit but what we were measuring was potential difference. Or pressure. Old electrical diagrams sometimes had high pressure and low pressure cables marked on them.In your river analogy the volts is the difference in height between one end and the other. Bit like pressure then.
perchypantherFree MemberI have a phenomenal memory. I can instantly recall with pinpoint accuracy some things that I read or heard or saw 40 years ago.
The problem is, it’s incomplete and utterly random.
I have zero control over what sticks and what doesn’t and most of it is completely useless.
It’s simultaneously a gift and a curse.
duncancallumFull MemberI’ve forgotten what I was going to say….
My memory can be absolutely fantastic like near photographic for stuff I’m interested in.
Or if I’m not interested or I’m stressed awful.
It’s like a newton’s cradle stuff on the edge gets knocked out.
i_scoff_cakeFree MemberYes, I much prefer written communication because it gives me more time to think and process. I tend to discover as I write too, which is why I never found much luck with the very formal and rigid essay plans that were drilled into me at school. When I write now, such as for an essay, I start with a few bullet points, references and some headings, and then go through many drafts to discover what I know and what I think. It’s like building a house from a rough concept.
If I do have to talk, I have a tendency to think openly as I do so and this doesn’t go down well with most audiences; they want a presentation, not an exploration. I also trip over words and slightly stammer.
Some people have a great memory. My memory is, in contrast, average.
jonbaFree MemberYou’d need to define intelligence. But it is a useful skill to be able to remember stuff and then apply it to situations you come across. There’s a balance somewhere. I know some people pride themselves on remembering facts but that isn’t useful if you don’t understand them.
I was quite good at remembering stuff for exams. But a significant amount of it was forgotten 6 months later unless used regularly. I also got quite good at doing exams as well. Spend as long studying the potential questions as you did preparing to answer them. Examiners aren’t always very original in their approaches and use the same questions all the time.
Have you looked at different ways of revising? We all process things differently. I do mentoring for exam age kids and some of them just don’t know how to revise. They try to just reread notes and hope they remember it.
Reading never helped me but rewriting did.
Understanding was vital not just remembering
I liked to produce structure and order to information
I tended to focus on past papers, questions and problems to force me to work through the information.
I tended to take a slow and steady approach rather than cramming. I seemed to take in information when I was relaxed.esselgruntfuttockFree MemberI’m dreadful at remembering things I’ve read no matter what it is, but tell me to meet you in 6 months time at a certain place at 15.27 & bring a book & I’ll remember. Old car reg numbers I can remember quite well too.
I’m reading a good book at the mo but can’t remember what It’s about!duncancallumFull MemberI’ve forgotten what I was going to say….
dpfrFull MemberWhile factual recall is probably less important than it used to be, because you can Google something in a minute, rather than having to dig around for ages, it is still useful to know stuff. Like several above, if I am interested in it, I will remember it, so I know all sorts of weird geeky stuff, but things like TV programmes that don’t interest me- forget it. I am lucky in being able to see connections and patterns in information, which is useful in my job (tecchie).
It’s very important not to confuse academic qualifications with intelligence though- that is a very limited correlation at best.
The topic ‘Intelligence and memory’ is closed to new replies.
